This setup ok w/ a 105 Amp Alt.
Old Nov 3, 2003 | 09:52 PM
kylem's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 Tuned Port Injection
Transmission: 700-R4
Hey guys I'm looking to put a 1200w Power Acoustik amp with two Dual Voice Coil Pioneer Premier 12's (TS-W125C/DVC), i just had my alternator rebuilt and i want to know if this setup will work fine with a Durlast Gold 105 alternator w/o the lights dimming when the bass hits.
Thanks for any help you can give me,
Kyle
Old Nov 3, 2003 | 10:03 PM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
If you want to play it safe just get a capacitor. I am running a 400 watt amp just pushing one 10 inch and I am using a 4 gauge wire with a 80 amp fuse all the way to the back seats then its dropped to a 8 gauge and I still get the head light dimming thing so I'm getting a cap.
Old Nov 6, 2003 | 03:03 AM
Kaukasion's Avatar
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
be sure to run thick enough wire
or you will get to much voltage drop @ the amp
alot of amps dont like voltage drop
lol
good luck with your setup buddy
Old Nov 7, 2003 | 06:14 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Get a cap.
Old Nov 7, 2003 | 10:56 PM
twiztid dreams's Avatar
Car: 84 Firebird
Engine: 2.8l
i would upgrade all the power wires under the hood first.
the wire from the alt to the battery and battery ground, and if u still have dimming either upgrade to a higher CCA battery or cap.
Old Nov 8, 2003 | 11:31 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
yeah, do the underhood wiring before you spend/waste your money on a cap. i've got around 800 watts rms on class AB amps and have not lights dimming. like the previous poster mentioned, run at least 4ga to all the important stuff under the hood (alt, battery, ground).
highspeedfreak
Car Audio
Sep 30, 2001 01:12 PM
89Firebird Formula350
Car Audio
Aug 30, 2001 06:41 AM
John Millican
Jul 11, 2001 07:06 PM
junkyarddog
Car Audio
Jun 23, 2001 09:26 PM
88irocz28
Apr 11, 2001 03:31 PM
