harness questions
Old Nov 30, 2003 | 11:12 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
harness questions
Ok, some of you may know I got my cd player stolen last tuesday.
Now 89Redbird is gonna give me his stock radio to me cuase he got a new one.
My problem is the only connector is the aftermarket one for a JVC. Its spliced into the factory harness cause my harness was trashed and the factory connector was cut off. Do they make a "reverse harness" that i can plug into the aftermarket connecter then into the stock radio?
Will a '89 radio work in my '85? His is a formula and I have a TA.
Any other suggestions on how to make this work?
Thanks,
Matt
Old Dec 1, 2003 | 09:22 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
You can get the harness your talking about and they are called a "reverse harness”.
Old Dec 1, 2003 | 12:28 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
iwouldnt waste your $ .......why do you want to keep the jvc one there anyhow unless your ganna buy another jvc sterio,,,but one shold come with it...just cut it off and wire in a new plug 89Redbird is ganna give you,,,if hes not giving you the harness to gust go cut one out of a another car at a junk yard. then wire it in, gm useed the same harnes plug in other decks and i may even have one here......
heres a diagram to help
Old Dec 1, 2003 | 12:29 PM
Matto'85TA's Avatar
NEEDAZ: Thanks!
Would places like Best Buy or Circuit City carry them, or would I need to go to Car Tunes or something?
jcurrieirocz: I would get the original harness, but there aren't many any thirdgens in junkyards in my area. Most are already completely stripped or stacked to be crushed. Also, my factory harness is far from stock, there is a lot of speaker wire in there, the factory wires aren't really used.
I am not getting the harness from 89redbird, only the radio.
Thanks,
Matt
Old Dec 1, 2003 | 04:22 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
it doesn't need to be from a thirdgen and as far as the speaker wire situstion goes just replace where you would put the factory conection with the speaker wires
Old Dec 1, 2003 | 07:27 PM
Car: '81 Trans Am
Engine: 6.6L
thats cool man but yah gm used the same plugs and decks in pretty much all there cars around that same year...i qarantee youd find one no matter what junkyard you go to. But yah eather way i think you should cut it out and wire it up right, especially if there are speaker wires and cr@p in there. Ive seen how some my previous owners wired there decks up and its ususlly never done the right way. but it is your car man so whatever you want to do.
Old Dec 4, 2003 | 04:52 PM
Matto'85TA's Avatar
Could someone post a pic of the factory connector for a '85 and a '89?
Thanks,
Matt
Old Dec 4, 2003 | 10:13 PM
Car: '81 Trans Am
Engine: 6.6L
Thanks,
Matt
I dont have a pic of the harness but it should fit into one of there right......
http://carstereohelp.net/wireharness_Delco1.htm
http://carstereohelp.net/wireharness_Delco2.htm
I think its the 1st one but im not + but i do know youll find both at a junk yard,,, i am farmilliar and prob have the kind of harness shown in (delco1 page) and its a three piece harness.
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
fbirdroller
Sep 2, 2015 10:27 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
