View Poll Results: Which is the best bang for my buck??
2 Adire Shivas
11.11%
1 Adire Brama
55.56%
1 Elemental Designs 12A
11.11%
2 Elemental Designs e120
22.22%
Voters: 9. You may not vote on this poll
Which Subs!! IM so confused!!
Old Dec 18, 2003 | 12:08 AM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
OK i think ive narrowed it down to these 4..tell me what you guys would go with.....whats the best bang for my buck
Old Dec 18, 2003 | 01:44 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
my vote goes with the brahma cause you can get excellent SPL with the SQ that comes with the adire name. Two shivas would require a fairly large box, but the brahma does not. With a smaller box you can be much more creative with the install.
I havent worked with ED products so i cant comment on them really...but you wont be disappointed with a single brahma
what size were you looking at getting?
Old Dec 18, 2003 | 02:03 PM
Marlow55686's Avatar
I just installed 2 shivas in my firebird and they are awesome. I have them powered by a tsunami DB1100, and it gets much louder than i need it. My only complaint about the shivas is that they have dual 8ohm coils instead of 4ohm or 2ohm so with both subs I can only get a 2ohm setup. It's alright but my amp will push 1100 watts @ 1 ohm and right now it's only at 325 watts RMS per sub. The brahma on the other hand has dual 2ohm so you can get it down to 1ohm if you need. As far as eDesign, my friend has the 12A and he likes it. All four are good choices, just match up your amp with your subs, whether max power at 1 or 2 ohms.
Old Dec 18, 2003 | 02:37 PM
9177's Avatar
I picked the 12A but its because i've had one and have had only limited use with brahmas. IMO either one would be a very good choice, both aimed at the same things in different ways and both do a very good job of acheiving it. I would not use the shivias due to box size problems. I'm pretty sure those subs like a tad bigger or even ported boxes
Old Dec 18, 2003 | 02:49 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
yeah i thought the 2 shivas would need considerably more box size than the the other choices, though im not certain, and while both the bramha and the e12a are awesome subs..i decided to vote for the 12o's due to the more surface area
Old Dec 18, 2003 | 02:58 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
http://soundillusions.net has very good info on all that stuff. and they were the only place that gave me info on EA subs i couls use. i mean they have a entire board just for it.
Old Dec 18, 2003 | 09:13 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
http://www.adireaudio.com/mobile_aud...hma_series.htm go to the brahma site and look at the videos of their subs and you will see a little of how these subs perform. BRAHMA!:hail: :hail:
Old Dec 18, 2003 | 10:45 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
how good is massive audio?
Old Dec 19, 2003 | 03:51 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
as far as subs and amps go they arent too special from what ive seen. I havent played around with any of their other products though
Old Dec 19, 2003 | 04:51 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
ok gosh dang it............its a complete tie all the way down the poll. Comon someone give me a tie breaker......tell me why i should choose one over the other!!
Old Dec 19, 2003 | 11:13 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
hehehe...i just like brahmas
Old Dec 20, 2003 | 04:37 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
ok so where is the cheapest i can get the brahma sub?
Old Dec 20, 2003 | 06:29 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
well for a new one the cheapest they sell for is for what they are marked for on the adire site... Ive talked to a few authorized dealers and they sell for the same price as on the site..or at least they did when i talked to them
Old Dec 21, 2003 | 01:53 AM
I got my shivas from Acoustic Visions because they have free shipping on Aidre subs. Here's the link to the brahmas there.
http://www.acoustic-visions.com/~aco.../adire_brahma/. You may find Brahma Mark I series on clearance at other sites, but I believe they have been sold out. You can also try http://www.speedsound.com/caraudio.a...ific=jmroqokrq, they have brahmas without the weird image on them.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
