Check out my custom vinyl project...
Old Jan 3, 2004 | 02:03 AM
joshp14's Avatar
Went out and bought some vinyl from an upholstry shop. Cutout the letters on cardboard and adhered them to a piece of MDF. Then I adhered the vinyl down onto the board/letters. This was a practice run as I will build my amp rack later next week with the finished product.
I am also doing a screaming bird logo too. Only thing I need to improve on is getting more adhesive right next to the letters' edges.
Old Jan 3, 2004 | 02:40 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
What kind of adhesive are you using? Contact cement works good, then use a small roller or rounded end of a toothbrush to bond the vinyl to the crevices in the letters.
Old Jan 3, 2004 | 10:29 AM
joshp14's Avatar
3M General trim adhesive is the stuff I'm using. Does a pretty good job. I may try to use a heat gun around the letters...that may help it stretch a little better. I used an eraser to push around the edges of the letters.
Old Jan 3, 2004 | 11:46 AM
88txiroc's Avatar
Josh,
The problem you are having with the edges may be due to the fact that the cardboard has straight edges. That is why I recommended that you use foam, as it will give a slightly tapered look. The roller will help, too.
Thomas
Old Jan 3, 2004 | 08:53 PM
joshp14's Avatar
I was thinking about that as well. I may try to use foam and then see what I get and then compare the 2 and see which I like better. I'm not sure if I will like the look of the foam as well as the cardboard, but you may be right. Thanks for the input.
Old Jan 3, 2004 | 11:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Take a sharp razor and cut a bevel on the edges of the cardboard a little. But you do need some sort of an edge like that to get it cleaner.
Old Jan 4, 2004 | 11:19 PM
joshp14's Avatar
I went ahead and did the foam as well. It looks bubbly and I don't like it nearly as much as the cardboard. The cardboard looks much cleaner and more definate. I may try to chamfer the edges as Gumby said. I think I just need more contact cement along the edges and I'll be good. I'll be sure to post pics when I'm done.
Old Jan 5, 2004 | 11:14 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you use wood and route the edges, it'll give the exact contour you are looking for, then you can adhere the vinyl to it.
Old Jan 6, 2004 | 01:20 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Looks good... I was kind of scared by the title of the thread at first! Let us know when you finish it up!
Old Jan 6, 2004 | 06:22 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Me too. I had an image of a guy trying to mount an old record deck in the console
Old Jan 6, 2004 | 08:24 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
what about using a heat gun to help shape the vinyl??
Old Jan 6, 2004 | 09:56 PM
joshp14's Avatar
LoL, you guys crack me up.
I may try using the heat gun and see how well it works on the final product.
Tibo
Mar 5, 2016 07:33 PM
gta90
Sep 15, 2015 04:00 PM
djmarch
Aug 19, 2015 12:07 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
