Will this work...?
Old Jan 23, 2004 | 01:47 PM
Scotty562's Avatar
Car: 2001 SS Camaro
Axle/Gears: I should know this
Will this work...?
i have a dual 4 ohm sub and a 2 channel amp if i put the + and - from each channel to the + and -'s of the sub, will it work? Or is this a no no?
File Type: bmp
Old Jan 23, 2004 | 03:41 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Why are you using an amp like that instead of a mono amp anyways?
Old Jan 23, 2004 | 03:58 PM
heavyhopper's Avatar
Car: 1984 z28
Transmission: 5spd
what amp is it? and it would not work well at all!!
Old Jan 23, 2004 | 04:44 PM
Scotty562's Avatar
Car: 2001 SS Camaro
its a soundstream rubicon 1000-2 amp, i got it cheap and if i bridge it with 2 subs it puts out decent power. im trying to put all 1000 watts into one sub but it would have to be 2 ohm to do that...
just wanted to check
Old Jan 23, 2004 | 05:56 PM
Car: 1984 z28
Transmission: 5spd
well just put pos to pos on sub and neg to neg on sub , and you will achieve a 2 ohm load which will be fine for a mono application..
Makaveli
Apr 25, 2003 08:03 PM
STIFFLER
Apr 25, 2003 06:30 PM
Drunken_Polak
Apr 22, 2003 12:23 PM
12 Sec GTA
Apr 17, 2003 03:01 PM
Xenodrgn
Dec 11, 2001 07:56 PM
