gauges not working...
Old Apr 17, 2003 | 09:53 PM
Makaveli's Avatar
well i have an 1986 2.8 V6 sport coupe. the temperature gauge doesnt work... so while we had a parts car here, i grabbed a complete gauge cluster off of an 87 camaro LT, but it was a 305 V8 car. the gauge cluster looks to be one whole unit... is it possible to swap just the temp gauges? i would change the whole cluster, but then the tach wouldnt work since its from a V8 car.
what else would cause the temperature gauge to not work?
Old Apr 17, 2003 | 09:59 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
How's the temperature sending unit/sensor? Is the wiring okay?
Old Apr 17, 2003 | 10:03 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
u have needles or dummy lights.....in my 87 SC LT i have dummies like this
Old Apr 17, 2003 | 10:32 PM
Makaveli's Avatar
yea mine are all needles... not lights, ill check the wiring with the temp sending unit/sensor tomarrow when im under the hood again. shoulda been the first thing i checked before i posted lol thanks for pointing me in the right direction, ill see if anything happens tomarrow.
Old Apr 18, 2003 | 09:10 PM
Makaveli's Avatar
yea we checked the sensors, and they are fine, and we found that the gauge is pegged all the way up, on the highest temperature, and when my dad and our mechanic neighbor jumped power to the gauge to see if it would jump or move but it didnt do anything... leading us to suspect theres something wrong with the gauge. its like stuck in the highest temperature, full position.
is it possible to swap just the temp gauges? or basically what i asked in my original post? lol
thanks!
Old Apr 18, 2003 | 09:18 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
is it up past 240? have u pulled the black trim and the clear piece under off and move the gauge with your finger? mine was stuck like that i just hit it with my finger and it fell down to 100, worked ever since, made me mad cause the previous owner didnt try that and tore all the wiring for the cooling fan out cause he thought the car was overheating and ghetto wired it up to a switch and put a new sunpro temp guage down by the gas pedal that i get my foot stuck between the back of it and the gas pedal...if u havent taken the pieces off, it only takes a few minutes and its worth a try, it might not fix it but i think it will
Old Apr 18, 2003 | 09:39 PM
Makaveli's Avatar
:hail: -> simple solutions that i dont think of
ill see if it works in the morning.
thanks
Old Apr 18, 2003 | 10:49 PM
Transmission: autos
lol, dont feel to bad man, i didnt think of doing it to fix mine for like a month..lol it gets stuck up there cause theres nothing to stop it at the top, i glued a screw up there to stop it..ya that worked great for a day or so..lol
Old Apr 19, 2003 | 12:24 AM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
My tach will peg sometimes when I start my car. Stupid test cycle I just took out the plastic cover inbetween the trim and the gauges so I can move the needle back if needed.
Old Apr 19, 2003 | 01:37 AM
Car: 1989 IROC-Z
Engine: 383 stroker
My temp gauge often got stuck on the black faceplate thing. It would do it every time, so I cut a little off the end so it couldn't
Old Apr 19, 2003 | 10:20 AM
Transmission: autos
just wanted to check if u worked on it yet? bubba, is your car 84K miles or 184K? i think it must be 84, way to nice lookin to be 184
Old Apr 19, 2003 | 10:59 AM
bubbakutz's Avatar
Engine: LG4
heh, no hundred yet.......right now its 86,000
Old Apr 21, 2003 | 11:57 AM
Transmission: autos
ya bubba, didnt think it was that high, makaveil, did u get it fixed?
Old Apr 21, 2003 | 02:09 PM
Makaveli's Avatar
i wasnt home most of the weekend, but i just fooled around with it a half hour ago or so and of course the lil bugger was stuck just as you said..
thanks a lot! :rockon:
Old Apr 21, 2003 | 02:11 PM
Makaveli's Avatar
smart idea, i think its time for that if it happens again
Old Apr 21, 2003 | 02:24 PM
Transmission: autos
anytime man, i really wanna get home, i hate these apple comps we got in electronics
Old Apr 25, 2003 | 08:03 PM
iroczVinnie's Avatar
Car: 89 IROCZ vert
Engine: 305TPI
re temp guage stuck
seems to be a common problem.
My temp guage did the same thing occasionly so I grabbed a pin from my mums sewing draw, filed the pin head (not the sharp end) so it was flat, cut it down to about 3mm, spray painted it black, and glued it. This peg now stops in flying up when you start and getting stuck. works like a charm.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
