Grommet
Old Jan 27, 2004 | 09:21 AM
nelsm6324's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Transmission: TH-700R4
Grommet
Hey everyone,
I looked all over the electronics and car audio thread, but could not find an answer to this question. Granted, it's a really stupid one, and everyone probably knows the answer, but I don't.
Where is the Grommet on the firewall so I can run my amp power wire through that, and not have to go through the door? please answer, I'm at a loss. It doesn't even say in my manual!
Old Jan 27, 2004 | 09:56 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
Standing on the passenger side of your car, hood open, looking at the firewall on the passenger side.
There is the fan housing, under that should be a cork shaped bump that is the same color as the engine compartment, which seems to flake off if you stab it with a screw driver, or a long fingernail. Like a pencil erasure.
That will be it.
Just push it out from the inside.
Or from the outside, you can stab a coat hanger, or an all through it, then look for it on the inside.
You might find yourself removing a little precut circular section of the fiber insulation to get at the hole from inside the car.
stab.. stab... STAB!!!
MWAHAHAHAHAHAH!!!
Old Jan 27, 2004 | 07:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Nelsm, I hope you were joking about the door... if you can't find that grommet (and I actually don't think I've ever seen it... odd, and I've had that heater box off before!), drill a new hole thru the firewall. Drill from the inside of the car towards the engine, and use things on the firewall as guides.
And there might even be a plug on the driver's side of the firewall that you can knock out with a punch; my car had one. Of course I found it -after- I had drilled a few holes over the years
Old Jan 28, 2004 | 09:00 AM
nelsm6324's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
no, i would never route a power wire through the door, what i meant to say (i guess i worded it wrong) is that I can't find the hole, but I won't go through the door.
Old Jan 28, 2004 | 12:23 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
When I was installing my bud's stereo in his 91 RS, we looked for the longest time for the little rubbery plug.
We finally found it in the location I previously described. It was painted the same color as the car, and it kinda hid under the casing for the fan in the shadows.
We had to enlarge the hole a bit to fit the 4guage wire through.
Then we sealed up around the wire with automotive adhesive goop.
Old Jan 28, 2004 | 01:31 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Another trick I've used is the huge boot that the antenna goes through.
I ran the wire down along the pass side fender through the rubber doo-hicky (that’s the technical word ) just behind the kick panel.
Don’t run it through the same hole as the antenna. It’s kind of hard to explain, but it’s like a circle inside a circle, and there’s a groove in the doo-hicky. That’s what I went through.
Old Jan 28, 2004 | 04:16 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've installed a stereo in all 4 of my thirdgens, along with in a few friends cars. I still haven't found a good grommet to run anything bigger than 10AWG through. If it's bigger than that, drill your own hole and make sure you install a grommet.
shr00m
Mar 23, 2016 01:41 PM
aaron7
Sep 30, 2015 09:15 AM
Anniversary-Z-man
Mar 31, 2005 07:21 PM
PAFORM350
Apr 2, 2004 10:57 PM
