stereo constantly skips
Old Feb 16, 2004 | 08:16 PM
MisfitZ28NYC's Avatar
Car: 85 Z 28
Engine: 74 350
Transmission: 5 spd
What is the best way to keep a cd head from skipping when driving over rough roads. I have an audiovox rampage head that has a mounting kit that is glued into the original spot. I have tightened the head into the metal sleeve as much as it can go, but it still skips on most all road bumps. My jeep has a panasonic head that never skips no matter how bad the roads are. The head in the jeep was professionally installed so i dont know if they used any kind of pading around the head. I installed the one in my camaro myself and just put the head into the sleeve. Any help would be appreciated.
Old Feb 16, 2004 | 09:28 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
Unfortunatly, if your CD player does not have good skip protection, then you're out of luck. The hu sits right above the drive shaft - and obviously, get a lot of impact when you're driving. When I first purchased my car it had a Sony HU, and the thing did nothing but skip. I put in my Kenwood KDC-MP8017 and never had a problem. << One of those hu's can be found on eBay for ~75.
Old Feb 16, 2004 | 09:47 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
i think it might be your particular HU...audiovox isnt known to be on the high-end of the spectrum.
As F-BodyFanatic said some of the cheaper kenwoods are excellent for skip protection, and the lower end pioneers are very very good aswell.
Old Feb 17, 2004 | 06:37 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: stereo constantly skips
That’s your problem. A CD player’s ability to resist skipping comes almost entirely from the mechanical construction of the CD mechanism. The cheaper HU just don’t have the ability to dampen the shock that the unit will get hit with, add to that a weaker laser and it’ll skip with the lightest tap. The Pioneers and Kenwoods are great at resisting skips. I like the Pioneer’s mech. a little better, the floating portion of the mechanism is a little heavier and seems to do better with shock. The optical pickups also use bigger magnets witch help keep the lens in one spot when the rest of the unit is shaking. Look into getting one of them.
Old Feb 17, 2004 | 09:26 AM
Car: 85 Z 28
Engine: 74 350
Transmission: 5 spd
Yea i'll probably look into getting the pioneer. Actually thats what my jeep has. For some reason I thought it was a panasonic.
Thanks for the info.
Old Feb 17, 2004 | 09:48 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
And actually, Pioneers are known for resisting skipping.
:lala:
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
meeklay812
Oct 1, 2015 03:46 PM
