Little help with amps plz
Old Feb 28, 2004 | 05:02 PM
MonteSmith383's Avatar
Car: 89 Formula
Engine: 5.7L 350
Im going to get two S12L7's i was wondering what amp to get. ive been looking at a D amp 1ohm KX1200.1 amp dont know if it will go good with the L7's little help would be greatly appreciated. and also some inshight into decks to go with the subs and amp Thx
Old Feb 28, 2004 | 05:41 PM
hfc's Avatar
hfc
Car: 99 Z28
Transmission: 6 speed
i have a kx1200.1 it's a nice amp. but i'd get a bigger amp for the L7's there rated for 750wrms.
my birth sheet from kicker was 1450wrms for my kx1200.1. try the sx1250.1
Old Feb 28, 2004 | 07:23 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Re: Little help with amps plz
what kind of box do you plan on putting the L7s in?? I would say get a JBL 1200 and you should be lookin good in a ported box
Old Feb 29, 2004 | 03:03 PM
Car: 89 Formula
Engine: 5.7L 350
Klaus audio makes a box and im gunna see if they make one for a bird. But is 1200 watts the rms of the amp im thinking maybe i should get a 1500 Watt rms i want this system to be nice !
Old Feb 29, 2004 | 03:05 PM
Car: 89 Formula
Engine: 5.7L 350
also should i get 2 ohm or 4 ohm?
Old Feb 29, 2004 | 03:16 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
it depends which amp you get...the JBL is stable at 1 or 2 ohms so you could get the DVC 4 ohm or DVC 2 ohm
the kicker amp puts out most of its power at 1 ohm mono so you would want to go with 4 ohm DVC if you're using two L7s.
I would say if you can find enough box space, just go with one L7 and give it the full 1200+ watts ported.
Old Feb 29, 2004 | 03:29 PM
Car: 89 Formula
Engine: 5.7L 350
whats the adv to one s12L7 over two ? i thought that if i had two L7's 750rms 1500watt rms on subs and then an amp with 1500 watt rms or upwards of it that it would sound louder hit harded and be overall better than one with its max power going threw it
Old Feb 29, 2004 | 05:52 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
with one L7 you could have an enclosure thats more suitable for the sub
Old Mar 1, 2004 | 01:35 PM
Car: 89 Formula
Engine: 5.7L 350
ok i understand the because the box has less air space then recomended for the speaker lets say u were building a geat system say what you would get 1500 watts rms and hits like a mother f*ck$r. because that s what i want! let me know how u would build one please
Old Mar 1, 2004 | 01:55 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
it depends how big of a box you plan on using...from my limited experience with L7s i think they respond fairly well in a larger ported box so i would say go with a single 12L7 in about 4.0 cubes tuned to 35 hz or so. Or if you can find 6+ cubes you could go with a 15L7 but its going to be tough to find that much box space and still have it look good.
personally i would say just one 12L7 run off of a JBL1200.1 in a well designed ported box should have excellent output in these cars. I would say get the dual 2 ohm because if you plan on competing you can run one amp per coil as the JBL amp puts out its most power at 1 or 2 ohms. Thats what i did in the past, i ran a 15L7 in 6.6 cubes gross tuned to 53hz with one JBL per coil and it was pretty loud and the sub took it just fine. Never had it metered though.
Old Mar 1, 2004 | 01:57 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
do you want to lose your hearing?
thats what you have to ask yourself
Old Mar 1, 2004 | 01:59 PM
Car: 89 Formula
Engine: 5.7L 350
well are there any other subs that are great or amps that are great that i can have two subs. i really like two subs i mostly listen to metal and techno but some rap i really appreciate you helping me out! if im going to go with one sub i would go with a soloX but dont know what amp to use. are the square subs beter? and i was going to just get a box from klaus audio, are their boxes up to par? agian thank you greatly for your input
Old Mar 1, 2004 | 02:01 PM
Car: 89 Formula
Engine: 5.7L 350
KJ i have no concept of how loud it will be! im trying to find out all help is apprediated i want it to be very loud not to win copetitions loud but loud enough to hit crazy and feel it outside the car
Old Mar 1, 2004 | 02:02 PM
Car: 89 Formula
Engine: 5.7L 350
he kj also u have any pics of ur monte i have an 88 SS just put a 10pt cage in it 3inch drop in the from sandblaster chassis and painter it looks sick but im interested in seeing yours
Old Mar 1, 2004 | 05:34 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
well its really a matter of how much box space you have. The SoloX is an amazing sub, but you dont have enough airspace for it to perform as well as it could.
if you really want two subs then you'll need something that works in a very small box. Maybe two adire brahma 10s would work for you http://www.adireaudio.com IMO two brahmas woukld have much better SQ than a single L7 and i think it would probably get a bit louder too.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
