Dual Voice coil over Single Voice Coil
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
What is the difference and advantage of one over the other?
I'm looking at this one
ED
Driver Name : e10Kx.44 /x .14
Voice Coils : Dual 2 or 4 ohm
Power Range : 150/400 watts
Applications : Sealed / Vented
Price - $75.00
any recomendations for a reasonably priced amp to go with it?
ED
Price - $75.00
Car: 83 z28
Engine: 300hp 355
the only advantage of a DVC sub is that you have more wiring options to achieve a more desired impedence load.
i suggest a JBL80.2 which will put out 160 watts at 4 ohm so you could go with the dual 2 ohm model wired in series
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'd suggest a mono sub amp like the JBL BP300.1, and the dual 4 ohm coil sub. The mono sub amp is stable when running a 2 ohm load (which is what parallelling the 2 4 ohm coils gets you), and the lower impedance allows the amp to produce more power. Overall, the 300.1 with the 2 ohm impedance will put out almost double the power of the 80.1 running a bridged 4 ohm impedance.
Car: 83 z28
Engine: 300hp 355
Why the 80.2 and not the 150.1? Are the JBL amps generally rated pretty close to what they are making? Also if it is 75w @ 4 ohms, and 150w @ 2 ohms, does it follow that it would be 300w @ 1 ohm?
Also, I think its up to 400 wrms, b/c eD recommends the avionix 400.2 amp, which brigded is 400 wrms.
Car: 83 z28
Engine: 300hp 355
i suggested the 80.2 over the 150.1 because if you want to upgrade in the future the 80.2 is a 2 channel rather than a mono so you could use it to power your speakers.
wouldn't the sub be grossly underpowered if it only had 80w to the sub? Would that cause a problem? I would definately like to have the option to wire up my 6 x 9's but my first concern is the sub.
The JBL 180.2 seems like a good fit.
Do all these amps have the "power switching supply that far reduces pull on the vehicle's electrical system"?
I'm wondering why the 180.2 is cheaper than the 300.1...
Originally posted by Boomin Boy
ya but his sub is only rated at 150 rms
A little more power is ALWAYS better than a little less.
Car: 89 Firebird
Engine: 2.8 MPFI
Not to mention as well that a one channel amp is usually a D-class amp. A D-class amp is actually better at amplifying low freq then the other normally seen class AB amp.
So that 150RMS will be put to much more efficient use in this case.
:lala:
:lala:
I wouldn't call it better. It requires less power to operate, which saves you a little money on wiring, and its disadvantages are such that they typically aren't audible in the bass frequencies.
Car: 89 Firebird
Engine: 2.8 MPFI
Yes, a class AB amp will do just as well powering subs as a class D. However, the point I was aiming for was that a class D amp will not work as hard in doing so as it is a more efficient amp and will use power more efficiently.
I would imagine it would run cooler, and provide a nicer signal when demands of quick power bursts are asked of it.
Please don't think that just because I say one thing is better than another that I am indicating the lesser product is no good at all. I am simply trying to provide a comparison just like everyone else.
Car: 83 z28
Engine: 300hp 355
so? My subs were rated at around that and had no problem taking my Kicker ZR600 at full power.
I just think that car audio is such an addictive hobby he might want to upgrade soon and with the 180.2 he can switch that to a frontstage amp with a larger sub amp
jer4251
Sep 27, 2015 09:52 PM
IROCNParts
Sep 24, 2015 10:50 AM
