What do you guys think about this Pioneer comp sub?
Old Apr 28, 2004 | 10:19 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
The Pioneer Premier Ts-W2000spl Subwoofer
heres the specs:
Features
Size 12"
Woofer Cone Material Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround Wide-Roll 3-Layer Fiber Woven Radial with Honeycomb Cloth
Voice Coil Dual 4-Layer, Long Voice Coil (2 x 4ohms)
Voice Coil Bobbin 4-Slit Glass-Imide
Conex Damper with Damper Ring
Top Plate Thick 7/8" (20mm)
Projected Pole Yoke with Vented Pole
Magnet Construction Double Stacked (110oz)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Silver Binding Posts
Specifications
Watts MAX. Music Power 2000W
Watts Nominal Power Handling 750W
Frequency Response 18Hz ~ 2,000Hz
Sensitivity 89dB
Ohm Rating DVC (2ohm or 8ohm)
Recommended Enclosure 1.5 Cubic Feet
I would be powering it with a Sony Sony XM-6001GXD Amplifier.
It puts out 600 rms watts at 2 ohms and 1000 watts at 1 ohm.
Also how does this sub compare to the elemental designs 12A or the Adire Brahma??
THANK YOU MUCH!!!
Old Apr 29, 2004 | 05:43 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
the brahma and ED subs are faarr better than that pioneer. out of the three i would take the brahma because of how well it performs in such small boxes, but i also havent had much experience with ED yet.
Old Apr 29, 2004 | 07:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Honda, Lamborghini, Ferrari.
Guess which one the pioneer represents.
Old Apr 29, 2004 | 08:42 AM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
I got his real bad feeling that its honda.
Where do I collect my prize?
Old Apr 29, 2004 | 05:45 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
ahahahahaha
you get a choice of a cookie or parade
Old Apr 29, 2004 | 08:21 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
so have you guys actually heard it?? What are you basing your opionions off of?
Car audio magazine did a reveiw of it.....heres a link to what they said: http://www.caraudiomag.com/testreports/0309cae_pioneer/
It got good reviews i was wondering if someone had actually heard it.
It is based off of a sub that is actually the worlds loudest by the way.
PLUS YOU CAN GET ONE NEW FOR 100 BUCKS ON EBAY!!!!
Old Apr 30, 2004 | 03:23 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
based on its specs its nothing too special
as far as the loudest sub in the world goes...90% of it is install
Old Apr 30, 2004 | 03:04 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Old Apr 30, 2004 | 05:17 PM
Jose'sRedTA's Avatar
Car: 87' Red TA w/ 92k miles
elemental designs rocks...well my only experience is with the e10kx.22...but it kicks butt...great service great people great product!
Old Apr 30, 2004 | 05:59 PM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
i think u should get the new e12av2 its sex
http://www.icixsound.com/movie/12avid.AVI
need i say more. Im sure eD will have a good preorder sale for them.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
nuggie
Aug 25, 2015 01:27 PM
Street Lethal
Aug 14, 2015 08:25 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
