antenae
Old May 6, 2004 | 11:27 PM
primerinstinto's Avatar
antenae
my antenae does not roll down! it's been like that since i bought it, somebody told me it was the cable? what do you guys think? is there something i can do to make it work? any helpful hints? thanks for your time fellas'---jorge
Old May 12, 2004 | 07:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The power antennas usually break; I replaced my power antenna with a regular black whip antenna for $15 from Strauss Auto. The cable inside is really just super-thick fishing line, and yes, it can crack. The motor can also burn out.
If you want to remove it to try and repair it, you need to pull the passenger tire off (for room). Remove the inner plastic fender. Then you'll be able to get at the upper & lower bolts that hold the power antenna in place.
Old May 12, 2004 | 08:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is a pink wire that connects to the radio harness and the ACC fuse supplies power to the power antenna relay located under the dash on the passenger side. Check those two items first. Here are the schematics if you need them.
Old May 12, 2004 | 08:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old May 12, 2004 | 08:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 3
Old May 12, 2004 | 08:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 4
speedingpenguin
Sep 28, 2005 03:27 PM
Alexcoqui
Aug 12, 2004 05:34 PM
Alexcoqui
Car Audio
Aug 11, 2004 06:52 AM
87camaro kid
Car Audio
Jan 7, 2004 01:15 PM
FAST RS
Car Audio
Jul 8, 2003 02:28 AM
