Sub / Amp Question
Old May 10, 2004 | 02:14 PM
Genesis98's Avatar
Car: 88 Camaro SC
Engine: 2.8 ->305->350
Sub / Amp Question
Okay I'm planning on installing 2 12" infinity Kappy Perfect's DVQ's and running them off of an Infinity Digital Beta 300 is there any benifit of running a second beta 300 amp or would I just be wasting my money?
Cliff Notes: Is it better to run 1 sub / amp or can I run 2 subs off of 1 amp and still maintain the same quality.
Old May 11, 2004 | 08:32 AM
Genesis98's Avatar
Car: 88 Camaro SC
This is a very simple question somebody has to be able to answer it.
Old May 11, 2004 | 08:44 AM
pardonme2711's Avatar
i would just run the subs in parallel
Old May 11, 2004 | 09:46 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
what are the specs of the infinity amp, i know about the subs, but infinity hasnt made car audio amps for many years and i have never seen one in person, so we dont know the specs on that amp, tell me more and we will respond...
Old May 11, 2004 | 11:39 PM
Genesis98's Avatar
Car: 88 Camaro SC
Output Power:
300x2 @ 4ohm
500x2 @ 2ohm
1000x1 @ 4ohm
Can be run in tri-way mode
Key Features:
stereo, bridged mono or Tri-way output
2-ohm stable in stereo (4-ohm bridged) MOSFET power supply
digital Class D amplifier
gold-plated preamp inputs
balanced differential inputs help keep noise away
Uniblock heat sink provides superb heat dissipation and RF shielding to help keep away radio frequency interference
set-screw terminals for crimpless wire connections
muting circuit prevents turn-on thump
signal-to-noise ratio 90 dB
power at 2 ohms 500 watts RMS x 2
variable (0-11 dB) bass boost at 40 Hz
frequency response 20-500 Hz
9-7/8"W x 2-3/16"H x 17-9/16"
Old May 12, 2004 | 08:57 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: Sub / Amp Question
4ohm per coil?
Old May 12, 2004 | 09:22 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
You should have no problem running the subs in parallel off this amp. You don't need another amp.
BTW, nice pairing of amp and subs.
Old May 12, 2004 | 08:36 PM
Engine: 350ci
demicon said what i think...
just so long as the load of the two speakers come out as a 4 ohm load to the amp thatll mean 500watts per sub, thats right about where i would push them.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
