4th Gen Radio in LOC
Old May 10, 2004 | 08:03 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
Does anyone know how to get a 4th gen radio out of LOC? I have a 97 Firebird CD player i want to put in my 87, but i cant get the radio to come out of loc mode.
Old May 10, 2004 | 01:18 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
it has been put into security mode due to its positive and negitive power sources being disconnected, you will have to ask who u got it from to get the code, or have proof of purchase, and take it to the dealer and see what they can do if anything
Old May 10, 2004 | 07:34 PM
Car: Trans Am GTA
There has to be a way to kill the internal clock. The thing cant hold power forever.
Old May 10, 2004 | 07:39 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
There are 2... 3 digit codes that GM needs to get your actual unlock code. once you have this you can disable the security feature. Most dealerships will do it for nothing, but alot will charge you a reprogram fee.
Old May 11, 2004 | 04:20 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
You can also try http://ls1.com/forums/index.html in the Electronics/Radios/Radar Detectors section. Look under FAQ at the top of that forum. Lots of other stuff there too.
Larry.
Old May 12, 2004 | 07:48 AM
Car: Trans Am GTA
Thanks for all the help guys, but the radio will not allow me to even try to enter the code. I hit almost any button and it says "InOp" anyway to get past this??
Old May 12, 2004 | 10:57 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
there is a sequence of buttons that have to be pressed to enter the code, perhaps someone who has a 4th gen radio will share
Old May 12, 2004 | 04:32 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Once teh Radio says INOP, you have to leave the ingnition in the on position for at least an hour to allow it to clear. Once you have done this you must hold down presets 1 & 2 , this will give a 3 digit code, then hold down the am/fm button and it will give you another code. I think those are the right combos again, I will look at my books at work tomarrow.
Old May 12, 2004 | 05:56 PM
pardonme2711's Avatar
www.ls1.com www.camaroz28.com try the forums at either one of those sites they can probably help u out a little more.
Old May 14, 2004 | 04:12 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Try this website:
http://forums.vmag.com/suvtahyuk1099/messages/7639.html
Read the last post dated 2/11/04.
Old May 15, 2004 | 05:17 PM
Cuno's Avatar
To unlock the radio, when you turn it on, and it has 'loc' on the display, press the 'hr' button for the first 2 numbers then press the 'min' button for the second set of numbers. Then press the 'am/fm' button. You should then be able to turn the radio on.
69 Six Pack
Oct 5, 2015 07:51 PM
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
