Where to put shaved antenna
Old May 27, 2004 | 06:26 PM
Paipe90GTA's Avatar
Car: 90' TA GTA
I shaved my atenna and put it in filler panel but it gets crappy reception, would it sound better if i put it under the dash?
Also how do i get the piece that covers most of the bottom of i took off the motor but cant get that big *** peice off could i just cut it?
Old May 27, 2004 | 09:27 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Re: Where to put shaved antenna
translate the bottom part better...
get a better remote mount antenna. i would reuse the old one. nor would i put it under te dash
Old May 28, 2004 | 10:29 AM
Paipe90GTA's Avatar
Car: 90' TA GTA
Its the big piece on the bottom 1/4 of the atenna and has i hole in the side for the contection.
you would or you wouldnt
Old May 28, 2004 | 10:36 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
my bad wouldnt... they sell high powered antennas that get better reception
Old May 29, 2004 | 02:01 AM
Kandied91z's Avatar
best option is to put a non powered antenna up under the dash period.
Old May 30, 2004 | 09:30 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
wouldnt teh electronics in and under the dash interfere with reception?? thats why i said wouldn't
Old May 31, 2004 | 04:42 PM
Kandied91z's Avatar
probably....
i've had my antenna shaved for 5 years now, i've ran everything under the sun from the radio shack 9.99 special to the $80 dakota digital untenna. i finally decided to do something cheap taht worked better then all the other options and i already had the parts. just giving suggestions, you do as you please.
Old Jun 1, 2004 | 11:42 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
try putting it in the sprae tire well or the other storage compartment across from it... or under teh bumper of the car...
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Thornburg
Aug 25, 2015 01:46 AM
madsv1000
Aug 20, 2015 06:45 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
