Help me out..Im a retard.
Old Aug 5, 2004 | 12:18 AM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
Ok, I have a AudioBahn 800x2 amp.
I have 2 Kove Audio subs, 2ohms each.
I have the subs run in parralel. I have a wire running from positive to the negative..and a positive hooked up to the positive terminal..and a negative hooked up on the negitive terminal. I have this done to both subs. I think its correct. But, this amp will barely push those subs. Even when I hook up one at a time and bridge it. Im really pissed off..and I dont know what the problem is. Thanks for the help in advance.
Old Aug 5, 2004 | 09:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
audiobahn sucks. But... it should still get pretty loud with that setup.
Your description of how you wired it isn't clear to me.
First of all, I'm relatively confident that an audiobahn would go up in flames if it was pushing a 1 ohm load, so you need to wire those koves in series to give the amp a 4 ohm load.
This picture shows how to series-wire a DVC sub. Series wiring 2 single-coil subs is exactly the same:
Old Aug 5, 2004 | 08:59 PM
semiller26's Avatar
Car: 1986 Trans Am
Re: Help me out..Im a retard.
In a parallel connection there should be no pos. to neg. connections anywhere. Those type of connections only occur in series connections. It sounds as if you may have things wired wrong. I had a similar problem with audiobahn equip. about 3 years ago. My problem was that the subs worked lousy when mounted magnet out. Once I mounted them regular instead of extra ***** they worked fine.
Old Aug 5, 2004 | 11:39 PM
87irocz350's Avatar
Car: 87 Iroc
Ok, thats the first way I had the subs ran. I had it A+ and A-. Then B+ and B- because I was running both subs. But, One sub hit hard..while the other just barely moved.
Old Aug 6, 2004 | 05:06 AM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
In Fact most AudioBahn Amps are one Ohm Stable, they sound like *** but they are stable with low impedance
Old Aug 6, 2004 | 05:13 AM
SS-84's Avatar
Car: 1992 RS
Which subs do you have?
RMS?
DVC?
2ohm?
4 ohm?
Try this wiring, This will give you a 2 ohm load with dual 2 ohm Voice coils.
Old Aug 8, 2004 | 01:02 AM
87irocz350's Avatar
Car: 87 Iroc
RMS?
DVC?
2ohm?
4 ohm?
Thank you very much. They are Kove Amrageddons. Dual Voice coil 2ohm subs.
Thanks for the help man.
Old Aug 9, 2004 | 09:40 AM
Jim85IROC's Avatar
If you said in the first place that the subs were DVC, you could have gotten the help you needed 4 days ago.
Old Aug 10, 2004 | 12:20 AM
87irocz350's Avatar
Car: 87 Iroc
Thanks for the help.
They run just fine now..but, that amp heats up pretty quick.
Can anyone suggest a goon Mono block amp with enough power to run both of these big boys? For around..$300-400?
Old Aug 10, 2004 | 01:17 AM
onebadwagon's Avatar
find a used MTX 81000D, or a 1501D.
a JBL BP1200 would work,
Cadence makes a couple high current amps that would probably work for you.
that's about all i can think of on your budget.
adam
Old Aug 10, 2004 | 08:01 PM
SS-84's Avatar
Car: 1992 RS
What is the model number of your AMP?
Old Aug 10, 2004 | 11:45 PM
87irocz350's Avatar
Car: 87 Iroc
A8002T
Old Aug 11, 2004 | 05:18 AM
SS-84's Avatar
Car: 1992 RS
That amp is rated at:
200w x 2 @ 4 ohm
400w x 2 @ 2 ohm
800w x 1 @ 4 ohm
For that amp, and dual 2 ohm voice coils
you have to wire the speakers to 4 ohm each,like the pic that Jim85IROC posted, then each speaker would hook up to a channel of the amp. You will only get 200w per speaker.
You need an amp that when bridged will handle a 2 ohm load.
Do NOT wire them the way the pic that I posted shows, you would then be trying to bridge the amp to a 2 ohm load and it will overheat.
Again, wire each sub for a 4 ohm load, then each sub to a channel on the amp. Or do not play them until you get a new amp.
What is the model number of the subs?
Or what series and size of Armageddon subs are they?
With out this info, we can not recommend a proper amp.
Old Aug 12, 2004 | 12:57 AM
87irocz350's Avatar
Car: 87 Iroc
They Are Kove Armageddon Z's.
2ohm. Dual voice coil. 600w rms each.
Yea, I have them wired the way you show me. The amp heats up pretty fast. Like I said..I just need a good mono block.
Old Aug 12, 2004 | 05:08 AM
SS-84's Avatar
Car: 1992 RS
ZM12-D2
600wRMS
Wire each sub this way. Connect each sub to its own channel on the AudioBahn amp
200wRMS per sub
For a new amp:
If your enclosure is sealed, this is a good buy:
http://www.cardomain.com/item/JBLBP12001
If your enclosure is ported look at this:
http://www.cardomain.com/item/JBLGTO12011
Old Aug 12, 2004 | 03:26 PM
87irocz350's Avatar
Car: 87 Iroc
thanks bro. Both amps look pretty sweet
Old Aug 13, 2004 | 10:14 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
yeah most AB class amps can only do a bridged 4ohm load... just use some common sense... if you are getting more watts than the amp is rated for, then you are running the ohm's too low
Old Aug 18, 2004 | 10:24 PM
87irocz350's Avatar
Car: 87 Iroc
Ok guys..I got a new amp. I got my hands on at MTX 8100..I think thats the model #. Its a mono block. I picked it up for $350 in good condition. Do you think this will be a good amp?
Old Aug 18, 2004 | 11:22 PM
the 8100D is a great amp.
that is a pretty good price for it.
make sure and run 0 gauge to it.
adam
Old Aug 23, 2004 | 09:24 PM
87irocz350's Avatar
Car: 87 Iroc
Alright, Round two.
Like I said..I bought a MTX 81000D. I kept the subs wired this way..but, when I hooked them up to this amp..Nothing. Once again I had to turn up the gain all the way just to get alittle sound to come from them. I am running the amp off 4awg wire. I know it needs 0awg..but, it should be hitting harder than what it is. Do I need to wire the subs another way..again.
Guys..thanks for putting up with me. I've had about 6 systems..and I've never had these kind of problems.
Old Aug 23, 2004 | 10:43 PM
ScrapMaker's Avatar
uh... I doubt the amp NEEDs 0 awg... 4 gauge wire should be fine for 1000d... obviously 0 guage wouldn't hurt but 4 guage is usually good up to around 1300 watts total combined power...
Old Aug 24, 2004 | 01:42 AM
that 8100d is not a very efficient amp.
are you sure you have your subs wired series/parrallel?
adam
Old Aug 24, 2004 | 11:25 PM
87irocz350's Avatar
Car: 87 Iroc
I went back through..rewired everything..and...
THEY WORK!
They sound really good with this amp. I dont have them in a car..so I just ran them in my box on my garage floor..Even with my 200lb friend standing on top of the box..they still hoped across the floor..
Thanks to everyone who posted here and helped me.
bamaboy0323
Sep 3, 2015 06:07 AM
conv90
Oct 27, 2004 06:09 AM
CHCKLS
Oct 17, 2004 01:07 AM
CaptPicardsZ28
Sep 26, 2004 12:42 PM
