Need Recommendations for High End setup
Old Aug 13, 2004 | 01:20 PM
rogz's Avatar
Car: 84 Trans Am HO
Curently i'm running 3 12' boston accoustics off a Soundstream amp and I have 2 6.5' Boston accounstic components in kick panels and 2 Pioneer 4 ways in the pillars. The amp running the 4 high end speakers is a 2 channel pheonix gold. My question is would the high end sound better and louder if the 2 pillar speakers were unhooked and all amp power was left to handle the 2 6.5' components? I also believe the components are capped off...is this good idea? I'm thinking the entire setup would sound better with the high end only coming from the front of the car from the higher end speakers.
Any thoughts?
Old Aug 13, 2004 | 01:39 PM
onebadwagon's Avatar
sound better, most definitely.
louder? possibly.
Old Aug 13, 2004 | 04:17 PM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
Run the front components from the amp.
run the rear fill from the head unit.
Old Aug 13, 2004 | 04:34 PM
rogz's Avatar
Car: 84 Trans Am HO
can't run the rear from the head unit..its only got RCAs from it
Old Aug 13, 2004 | 07:19 PM
SS-84's Avatar
Car: 1992 RS
You have no speaker leads???
Only pre-outs?
Old Aug 13, 2004 | 07:20 PM
rogz's Avatar
Car: 84 Trans Am HO
yup only RCA outlets on the back of the head unit, there is no 4x50 or whatever since there are not speaker wire leads
Old Aug 13, 2004 | 10:58 PM
SS-84's Avatar
Car: 1992 RS
Which Head unit do you have?
Old Aug 14, 2004 | 06:32 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
Yup, only RCA outs, probably several pairs.
I've seen an Alpine and a Clarion like this. They know that it is a SQ HU and anyone serious about sound is not going to be powering anything with a skimpy HU amp, so they just skip that step and offer a clean signal source and nothing else. High end home component systems have been doing this for years. most mid range to high end Sony, Yamaha, Onkyo, Technics ect.. offer recivers which can power 4 to X speakers, but the people who really want to custom tailor thier systems or DJs work with signal sources and use a seperate amp for final output power.
Another good thing about that is that there is less heat to casue any heat related problems in the HU, without a built in amp it can stay cool.
The drawback is if your amp dies and you have to send it in for repairs.....then you don't have any backup plan, so you might want to keep some cheapie amp around just to be sure you always have music!
Old Aug 14, 2004 | 09:46 AM
rogz's Avatar
Car: 84 Trans Am HO
The head unit is a panasonic from a few years back...at the time i was told it was a higher end unit, hense the RCA outs in the back
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
