Cheap Amps?
Cheap Amps?
Just wondering. If i got a cheap amp with like 2400W. Could I use it to push my 2 subs that are rated at 350W RMS? I mean I know there is no way that there is actually 2400w there, but could it still push something like that without sounding bad? Thanks
Car: 89 IROC-Z
Engine: 355 TPI
And how it would sound is another..... Probably would still be better off with a quality amp with a lower power rating. The argument could be made that THD would be higher with that amp at a lower level. That would depend on cross over distortion.....
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There aren't too many company producing class d amps. Most of those cheap ones use the same board, which I think puts out around 1,000 watts. So... some no-name "1500" or "2500" watt class D amp should still put out an honest 1,000 watts or so.
You can find decent 1,000 watt class D amps for under $200.
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
Just be sure to leave the lighting rod in the box. If you hook it up, it may pick up a direct hit and actually put out 2400 watts!!
Originally posted by NEEDAZ
Didn't think he was asking specifically about Class-D.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
a good amp with power and for the money look for a amp called solid audio.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Doesn't really matter if it puts out enough wattage... like someone above said, the distortion is what ruins the sound!!
Trust me, I had a Urban Audioworks 800.2 amp hooked to some Alpine Type S's in a friend's truck... they sounded like Delco 6x9's!!
raymondandretti
Sep 27, 2015 06:43 PM
Damon
Sep 26, 2015 04:29 PM
