amp power
Old Aug 26, 2004 | 09:49 PM
Ericritter7407's Avatar
Car: 88 Camaro Iroc-Z
Engine: 350 carbed bored 30 over
amp power
the amp I have in my car now is a piece of **** (legacy) but it took a 12 volt power supply the amp I just bought the rockford fosgate P6002 takes 14.4 volts..do I have to change the wires or what? thanks
Old Aug 26, 2004 | 10:27 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
No, leave the wiring alone. It gets what it gets, if the cars is only putting out 13.2 volts or 12.6 and not 14.4, guess what? It's not getting 14.4 volts!!
What you should be concerned about is the power requirements of the amp. It should have at lease 8 gauge, but if it is a more powerful amp, like 350 watts rms or up, 4 gauge might be better. I don't have a chart in front of me and people will argue all day long about what is overkill and what isn't. Basically, you will need thicker wire as the power requirment goes up.
If I remember right, thirdgens do get to that 14 volt threshold while running. In this case, you're in luck, you will get full performance from the amp...If not, who cares..if it's a good enough amp, it should sound fine anyways.
Old Aug 26, 2004 | 11:11 PM
thanks, the spec testing sheet that came with it said that it puts out a combined RMS power of 744 watts in two ohms is that going to be ok for 8 gauge wiring
Old Aug 27, 2004 | 01:06 AM
onebadwagon's Avatar
no. just run 4 gauge.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
sailtexas186548
Aug 24, 2015 10:11 PM
ZsTransAm
Aug 11, 2015 07:30 PM
