E brake handle noise
Old Aug 28, 2004 | 10:48 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
I have a decent setup in my car and when its a lil low or even off the e brake bottum on top of the handle vibrates like crazy. Its a 5 spd car, so the e brake in on the console. ANy ideas guys?
Old Aug 29, 2004 | 12:11 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
if it is just the leather handel part remove it and put some ruber coating on the metal part. use some weather strip adhesive or something like that gasket sealer may work also. then put handle back on when it sets up. this would work like an insulator to stop vibration. if it is a mechanica; part inside the console you'll have to search for it and maybe put some heavy grease on it like white lube or red bearing grease.
Jeff
Old Aug 29, 2004 | 03:11 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I don't have a leather handle. Its out of a thirdgen, then button on the end of the handle (release button for when the brake is set) vibrates like hell and don't know what to do. Thanks
Old Aug 29, 2004 | 07:22 PM
JeffW's Avatar
Engine: 305 tpi LB9
got a pic of what it looks like?
Jeff
Old Aug 30, 2004 | 09:50 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Yes but hwo do I inset an image?
Old Aug 30, 2004 | 10:06 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
like this [img] http://url.here [/img] but without spaces
And the piece he is talking about is the stock plastic handle, not your silly optional leather one; they're the same, one is just plastic. But anyway, you could wrap the button in rubber or spray-on bedliner or something.
Old Aug 31, 2004 | 07:22 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Go to a fabric store and get some felt, the go to the car parts store and get some weather stripping adhesive (the 3M stuff will stick anything to anything)........
Old Aug 31, 2004 | 10:18 PM
Engine: 2.8 Lt
Transmission: 5 Spd
These all sounds good, but how can i wrap it with anything when I do have to use the e brake all the time, which means I have to push that button in, not much room there. If i put tape on it, it won't push in. How do I do it? Thanks
Old Sep 1, 2004 | 09:14 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
to be honest i had the exact same problem...what my solution was for the time was to wedge a piece of paper in there..May sound stupid...but it worked..so yea
Old Sep 3, 2004 | 11:26 AM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah but then you can't use it, thats the only downside and with a 5 spd, you need it LOL. There ins't really much room on the side either
Old Sep 5, 2004 | 08:09 PM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
get a thin piece of cardboard and cut it so it's the same size as the button so that it will slide into the sleeve just like the button will... but make sure the cardboard is thick enough to put pressure on the button so that it won't vibrate
-Kyle-
Old Sep 6, 2004 | 12:06 AM
Engine: 2.8 Lt
Transmission: 5 Spd
I'll try it, it had to be pretty thin though, i'll give it a try tomorrow. Thanks
dbrochard
Oct 3, 2015 12:43 PM
GouldyGTR
Sep 7, 2015 09:05 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
