What Companies Make Good Sub Boxes?!
Old 10-10-2004, 08:04 PM
  #51
HamiltonAudio's Avatar
Car: 1982 Camaro Z28
Engine: hot 355 ci small block
Transmission: built TH350
Originally posted by onebadwagon
yes, absolutely, generally the tuning frequency will be approximately the lowest the box will play without unloading the driver and causing a problem.
but yes, there will be a definite gain at the tuning frequency, while still having a good sound above that frequency.
adam
i fear we're being a little too generic here. the box doesn't unload right at tuning, it /begins/ to unload. major effects are noted several octaves BELOW port tuning frequency. so if the box is tuned sufficiently, the major problem frequencies will be well below what normal music has material in anyway. at higher power levels, I always strongly recommend a subsonic filter to prevent issues. either way....
you're not mentioning anything about the natural gain of the vehicle. sure the box, on paper, may rolloff at a certain point, but the 3rd gen has a serious transfer function that makes up for a lot of it.
just my 0.02...theres a LOT more factors than those just glazed over here...
bmoney
Old 10-10-2004, 09:00 PM
  #52
onebadwagon's Avatar
i know, i was just adding my .02 cents to what was already posted by you and jim.
adam
Old 10-16-2004, 04:28 PM
  #53
darksyde's Avatar
Car: 1988 firebird formula
Engine: 5.7
Transmission: auto
bass tube
try a bass tube.....ive got a 10 inch bass tube that fits perfectly in my trunk well ...got it for 5 bucks at a yard sale ....came with an mtx road thunder sub.....changed the sub to a cerwin vega vmax ....it now sounds better than the 2 12 inch subs i had mounted in a box and im only using one sub...ithttp://store.teptronics.com/teptronics/...they have bass tubes in here if u are interested...
customblackbird
08-15-2021 10:16 PM
9192camaro
16
02-03-2019 12:21 AM
sweet_87_iroc
Exterior Parts for Sale
03-27-2016 04:05 PM
Linson
08-21-2015 02:12 PM
bryan623
08-10-2015 11:33 AM
Quick Reply: What Companies Make Good Sub Boxes?!
