Subwoofer recommendations
Old Sep 15, 2004 | 07:28 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I just popped/blew the 2 10" subs in my car today (JL Audio 10W0) and since they were the better part of 6 years old I figure there may be something better out there. I need a pair of 10" 8 ohm subs. Any preferences?
Old Sep 15, 2004 | 07:50 PM
onebadwagon's Avatar
how big is the box you are using?
you can get any Dual 4 ohm sub you like, and there are ALOT of them.
Sealed box? I like the w3, MTX Thunder 5500, and the memphis Power Reference are pretty good for a cheap sub.
I'm sure others will chime in with opinions aswell.
adam
Old Sep 15, 2004 | 08:55 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
the type are is a great sub, for its price. i have no regrets and its all the bass i need. my only complaint about the type r is that it tends to sound better on the hard hitting bass notes such as rap. maybe i just need to be educated a little more though.
Old Sep 16, 2004 | 12:23 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
How much power does your amp put out in RMS?
Old Sep 16, 2004 | 05:57 AM
Mongoose's Avatar
Car: 90 Formula
It's an Alpine T500 in mono. I think it's in the 300 watt range. The box is a sealed one made into the lower half of the well.
Old Sep 16, 2004 | 09:17 PM
Is that the MRV-T500 V12 amp? If so, thats a good amp. I had a pair of 10W6 subs wired to 1.5 ohms running off one for a while till I decided to go with only 1 sub.
I would look fo a sub rated for around 200 watts RMS, since the amp probably wont be putting out much more the 150 to each sub. Either an 8 ohm SVC or a 4ohm DVC.
Old Sep 17, 2004 | 06:30 AM
Mongoose's Avatar
Car: 90 Formula
It is a V12 amp. I was looking at either going back with 10W0s or switching to Rockford Fosgate or Polk's GNX line.
Old Sep 18, 2004 | 12:22 AM
given those, i'd probably pick up the w0's.
adam
Old Sep 18, 2004 | 03:31 AM
adam
Yep.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
84 TA NV
Sep 6, 2015 08:02 PM
tc7761
Aug 30, 2015 09:45 AM
Chuck84TA
Aug 27, 2015 11:14 AM
Jim 86 Bird
Car Audio
Nov 22, 2000 08:43 PM
