Power antenna installed
Old Oct 19, 2004 | 07:20 PM
NascarFool's Avatar
Car: 1989 Iroc-Z
I finally got an OEM replacement power antenna today. I got one from gmpartsdirect.com for about $103 shipped. The local dealer wanted about $205 for the same antenna. Tonight I installed it along with the Alpine that I had pulled out. The antenna goes down when you plop a CD in the deck and back up when you eject the CD as long as it switches to am or fm. Pretty cool. Looks like I'll be calling Sanyo to RMA this POS Sanyo deck, it distorts badly before it gets close to loud on the oem speakers. The Alpine cranks loud with no distortion.
Old Oct 19, 2004 | 08:14 PM
HamiltonAudio's Avatar
Car: 1982 Camaro Z28
Engine: hot 355 ci small block
Transmission: built TH350
Re: Power antenna installed
good man. glad to hear ur success story. but you didn't have to buy a gm antenna you k now Metra sells a pretty wide range of fully automatic power antennas that come with the base plates and locking nuts that match most oem installations. I don't have the price list on hand, but I can tell you it wouldn't be close to $103.
just as reference for the future.
bmoney
Old Oct 19, 2004 | 09:00 PM
NascarFool's Avatar
Car: 1989 Iroc-Z
Have you tried the Metra antennas ? I did and it would not fit up in the fender area. Plus I am restoring the car and OEM parts are my best bet.
Old Nov 5, 2004 | 04:44 PM
Racer350's Avatar
Car: 1988 IROC-Z
Axle/Gears: 3.45
What was The part # on that antenna from gmpartsdirect
Old Nov 5, 2004 | 05:12 PM
85_ZED28's Avatar
Car: '85 Z28
thats pretty cool!
Old Nov 5, 2004 | 08:14 PM
its cool, but not a very big deal at all. most decks now have a dedicated ANTENNA output that does just this. only powers on when the radio is activated - anytime you move away from the tuner (to cd, changer or off) it powers down.
bmoney
Old Nov 5, 2004 | 08:21 PM
85_ZED28's Avatar
Car: '85 Z28
bmoney
[waynecampbell] I was not aware of that! [/waynecampbell]
Old Nov 6, 2004 | 02:37 PM
<waynecampbell> way! </waynecampbell>
cash-monay
Old Nov 7, 2004 | 11:11 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I just replaced the mast in a mitsubishi power antenna today.
The new unit would have been $245 from Mitsubishi, the mast was only $32 (still a rip-off)
I had to undo the cover and remove the old broken plastic chain pieces. I re-greased the gears and fed the new mast in while a friend turned the key on and off, it was easier to just hook it up to the car instead of bench powering it.
I'm much happier with keeping it original, I've heard aftermarkets can fit well and often work better, but $32 isn't bad.
Does GM sell the 'rebuild kit' for power antennas?
Another tip I've heard was to apply some white lithium grease lightly with a rag while the antenna is up, this keeps it from binding and breaking itself.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
