Sound Through Vinyl?
Old Dec 12, 2004 | 01:12 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
I want to cover the rear sail panels with some type of vinyl does anyone think vinyl is bad or would it be ok? ...It's just i bought new sail panels prolly a year ago and they faded really really fast
Old Dec 12, 2004 | 11:31 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
It will block alot of the highs. Might want to perforate the vinyl where the speaker will play thru.
Old Dec 13, 2004 | 12:40 AM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
what do u mean by perforate?
Old Dec 13, 2004 | 02:25 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
to punch many different (little) holes in the material to let the sound through.
webster says,
"Perforate
Adjective
1. Having a hole cut through; "pierced ears"; "a perforated eardrum"; "a punctured balloon".
Verb
1. Make a hole into.
Synonyms
perforated (adj), pierced (adj), punctured (adj), punch (v)."
Old Dec 13, 2004 | 09:41 AM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
thanx guys ...using vinyl now
Old Dec 13, 2004 | 06:02 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
Has anyone done anything like this before ....I want to reapolster the sailpanels with the vinyl to match the carpet and have the speaker grills work too? has anyone done this or anything similar
Old Dec 14, 2004 | 08:39 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
um i guess you could use the speaker grills but you would have to cut the vinyl out at the edge of the speaker and tehn mount your speaker with the grill according to insttructions
Old Dec 15, 2004 | 05:32 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
well I was actually thinking on mounting the Grill right onto the sail panel board instead i think i'm going to have to cut the grill a tiny bit and use some small bolts to bolt it to the card board panel itself i'll show u guys how it turns out and You all can flame me on how it looks It's shouldn't look too bad tho I'm going to use vinyl too so it should look a lil better
Old Dec 15, 2004 | 06:43 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
do this instead.. cut the sail panel so the grill can go thru it and that'll look pretty awsome if you cut it welll enuff
Old Dec 16, 2004 | 11:14 AM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
don't worry i'll keep u all posted.....
Old Dec 16, 2004 | 07:37 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
Alright I did it tonight I just did one side but it came out pretty good so take a look ....oh I covered them in vinyl and found the speaker grills that came with my infinitys that with it a long time ago. but here are some starting pics....just a few showing what i did then the end product...any questions are appreciated
Old Dec 16, 2004 | 07:38 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
Old Dec 16, 2004 | 07:39 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
Old Dec 16, 2004 | 07:42 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
3. after i put the vinyl on.....
Old Dec 16, 2004 | 07:45 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
4. Test Fit
Old Dec 16, 2004 | 07:48 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
5. Final Product......That previous pic i bent the speaker grill but it's ok it bent back without a crease lol
Old Dec 17, 2004 | 10:54 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
that is what i was thinking of..... looks pretty good
Old Dec 18, 2004 | 05:27 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
or what you could have done is taken some fiberglass resin and resined the **** out of that sail pannele then cut the hole the size of your speaker and moutn the whole speaker and grill to the sail pannel and cover it in what ever you wanted. this way you don't have a big gap behind the grill and speaker when you look through the grill.
Old Dec 19, 2004 | 09:23 AM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
I don't know what u mean by gap but the grill is much larger than the speaker...but i think i know what u mean cuz u can see the dynamat ...
Old Dec 19, 2004 | 09:27 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
if you mount the speaker to the sail panel tho i think it would vibrate........ alot
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
