big problems
Old Dec 20, 2004 | 04:22 PM
kammi10's Avatar
Car: 1989 camaro
big problems
ok so i was helping a buddy of mine hook up a system in his camaro yesterday and i got it all in, worked great. now today i swapped out soem subs for soem different ones and he diecided he didn;t want them i i hooked the other onesback up. got all doen and everything it blew the fuse's. got soem new ones put it in and turned it on it would send no signal out to the subs. power wire is fine but it jsut won;t send signal out to the subs. turned it on and had the subs hookd up right after i put new fuses in and it smelt real bad liek it burnt up the subs. so i unhooked it and could never get it to work again. by the way the amp is a new rockford 500.2 anyone know why maybe this is doing that
Old Dec 20, 2004 | 04:39 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
little light on the amp turn on? if u smell that burnt smell.. probably blew the subs.. test the sub out on like a system in the house not in a box.. if it souns clear its fine .. if it sounds all distorted ..like sratchy plastic... she blown.. what i usually do to see... did u see if the protect on the amp is turnin on.. it could be a lot of stuff.. letme kno
Old Dec 20, 2004 | 04:45 PM
kammi10's Avatar
Car: 1989 camaro
amp turns on but when u try hookin the subs up it liek sparks like its grounding out. i think it blew the amp
Old Dec 20, 2004 | 04:48 PM
Car: 2002 SS
Engine: Ls1
best thing to do is have the amp tested at a car audio store or hook it up to a friends system... usually what i do
Old Dec 20, 2004 | 05:02 PM
/\/3\/\/l8l3's Avatar
you must have changed the subs while the amp was on?
Old Dec 20, 2004 | 05:05 PM
kammi10's Avatar
Car: 1989 camaro
i don;t think it was but it might have i couldnt; see the amp so i couldnt; tell if it was lit up or what
Old Dec 20, 2004 | 06:16 PM
kammi10's Avatar
Car: 1989 camaro
figured it out
right channel is blown
Old Dec 20, 2004 | 07:55 PM
Car: 2002 SS
Engine: Ls1
oach... poor rf amp i love them.. well anyway buy the same amp from a dealer then send the bad one back and keep the good one
Old Dec 21, 2004 | 07:16 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Beat me to it. Was going to say DC on the outputs of one of the channel. Send it back to RF, they have GREAT service.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
