What type of Liquid Nails should I use for glueing MDF box??
Old Dec 23, 2004 | 08:17 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
not sure what type is best for MDF?? The heavy duty??
Old Dec 23, 2004 | 08:38 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
heavy duty is what i used
Old Dec 23, 2004 | 10:08 PM
9177's Avatar
Use regular wood glue it makes a better bond. If you need to seal it then use silicon on the inner edges.
Old Dec 24, 2004 | 12:02 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
thought about using that Gorrilla Glue any thoughts
Old Dec 24, 2004 | 12:26 AM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
black silicon works good for sealing the box.
Old Dec 24, 2004 | 08:15 AM
9177's Avatar
Never used it. For as many boxes as i build its not worth the extra money imo.
Old Dec 24, 2004 | 02:54 PM
nolanr0413's Avatar
Car: Trans am
gorilla glue is a pain in the butt to use , but its the best stuff to use.
Old Dec 26, 2004 | 07:08 PM
NjccBflo's Avatar
Gorrilla Glue.
Or some form of wood glue.
When the (WOOD) glue sets, it will be stronger then the actual mdf.
Old Dec 29, 2004 | 12:09 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You can use wood glue like Titebond or Elmers Yellow (not white!!)
Old Dec 30, 2004 | 06:40 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Gorilla Glue is the bomb. And like they said it will cure very hard not to mention its wateproof and slightly expands as it drys to give a very nice, air tight seal. I don't think its hard to use, just like anyother wood glue. Just take a damp cloth and apply to one piece of material. Apply glue and put together. THen I like to use a few screws on each piece rather than set up clamps, that way you can continue to work while it drys.
Old Dec 31, 2004 | 10:55 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Semper Fi....shouldn't you use a combination of glue and screws when building a box?? That's how I always figured you were suppose to put one together. So my best bet for a strong box would be gorilla glue, wood screws, and silicon to seal all joints?? How about the silicon, what would be the best choice or does it really matter??
Old Jan 1, 2005 | 09:02 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Of course use screws. As for silicone, no it really doesn't matter how much you use. It doesn't take much though, just enough to seal it air tight.
Old Jan 1, 2005 | 04:30 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
gorilla glue is pretty bomb. we used it in teh shop at school and you could glue anything to anywhere( we've glued a quater to the floor and other random stuff to the walls) just like super glue tho.. dont get it on urself unless u like semi perminent bonds with urself and the things you touch
Old Jan 5, 2005 | 09:43 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
Use wood Screws....
Old Jan 6, 2005 | 07:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I intend to try liquid nails myself sometime soon. I have a feeling that I might like it better than wood glue. My main complaint with wood glue is that with something as absorbative as MDF, most of it soaks in and doesn't create as strong of a bond at the glue joint as it does with solid woods. While it's still sufficient for holding enclosures together, the idea of something thicker like Liquid Nails intrigues me. Not only will it not soak in as much, but it'll do a good job sealing tiny gaps between the wood, negating the need for silicone.
Either that or the stuff just plain sucks. Either way, I hope to find out soon.
Old Jan 7, 2005 | 02:16 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Liquid Nails Adhesive Caulk is what you want.
http://www.liquidnails.com/caulks/ac-138.html
TECHNICAL INFORMATION
Application Temperature: 40° to 100° F (3° to 38° C)
Service Temperature: -20 to 200° F (-29° to 93° C)
Adhesion: Good to most common building substrates
Extrudability: Excellent
Shear Strength: 24 hours – 300 psi
7 days – 380 psi
Consistency: Smooth paste
Durability: Excellent
Flexibility: Good to -10°F (-23°C)
Those are the key specs to look at.
For instance, the Shear Strength of the "Heavy Duty" stuff is 240 PSI, and the Serv. Temp is 0*-140*
I've only used the Heavy Duty and had excellent results, but if you want something better, this is it.
tyeo098
Nov 30, 2015 06:27 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Rally Smith
Sep 14, 2015 06:59 PM
Hello, Michael
Sep 11, 2015 01:10 PM
