Performance Sound Amp Button?
Old Mar 2, 2005 | 10:59 AM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
1985 T/A 5.0 4BBL LG4. My Car has the performance sound option. Behind my sail panels I have what look like custom boxes, with a 4x6 and what looks like a 4.5 or 5.25 woofer. Is this the stock setup for the performance sound option? Also there is a Switch on the dash panel with a slider. Stock Amp Turn on and Gain(where is the stock amp?) With the stock deck it seems to work. With my aftermarket deck I'm not getting anything. Even though I spent the money on one of those wiring harness adapters. Stereo will play but the amp button does not seem to work. What Gives? I love this site!
Old Mar 2, 2005 | 01:30 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
ok , that setup is stock , i had it in my 85 trans am , the amp is lockated above where a passenger would sit in the front seat . their is an access panel and then its under there . It shouldnt work because the stock stuff is like 8 ohms and the aftermarkets stuff is differnt . they had to run new wires when i had an aftermarket cd player put it .
Old Mar 2, 2005 | 02:14 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Thanks for the info! Your car is hot man! What did you pay for your ram air hood?
Old Mar 2, 2005 | 04:44 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
18inchboyds, the amp wouldn't happen to be a small black box bolted onto the panel behind the storage pouch on the passenger side, would it? I had to remove most of the interior panels to fix a problem I was having with the headlight switch, and I couldn't seem to identify what that thing was.
I don't have the performance sound package, though.
Old Mar 3, 2005 | 07:38 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
thats where my amp was , i cant think if anything else is under there , but thats where my amp was. Well its still in there .
THe hood cost around 600 shipped , this was back in 03 so it might be cheaper now .
Old Mar 17, 2005 | 02:22 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
its not the computer, is it? that's exactly where mines at.
Old Mar 25, 2005 | 03:02 AM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
yup i just found out that if you have the performance sound option you get an amp right behind where the ecm is. i attached a pic...
Old Mar 26, 2005 | 10:34 AM
Tonyrodz's Avatar
Transmission: auto
That's an aftermarket amp in that pic--not factory at all.
Attached Thumbnails Performance Sound Amp Button?-c-documents-settings-owner
Tonyrodz's Avatar
Transmission: auto
another
factory amp
Old Mar 26, 2005 | 11:03 AM
ScrapMaker's Avatar
that would be cool if there was enough room to mount a real amp in there... but I've never seen a good amp that small.
Old Mar 29, 2005 | 03:52 PM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
Does any one have a wiring diagram for the factory amp.
My 89 Firebird does have one but I want to install one.
what are inputs on the factory amp? Is it just the channel inputs coming from the stereo?
Thanks,
Birdofprey83
Old Mar 29, 2005 | 03:59 PM
its a delco amp
Old Mar 29, 2005 | 04:26 PM
ScrapMaker's Avatar
what kind of power would you see with an amp like that? and would the headunit of a car with an amp have no internal amp?
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
luvofjah
Sep 3, 2015 07:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
