wierd noises
Old Jul 31, 2005 | 09:58 PM
  #51
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
yeah I think you can get a 5mp for like $300
only 300ft? when I was at the beach with my 600 watt 4channel, I could easily hear it further than that... now with the nINE.4 it's a great deal louder... plus now my high's are amped... my car is great for the beach or tailgate parties... but I hate the bass in the car, as it rattles everything.
Old Aug 1, 2005 | 06:35 PM
  #52
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
well im assumming because that was with the ttops on and i was guessing at how far i was, plus i didnt want to get too far away from my system with cops and low lifes around
Old Aug 1, 2005 | 06:59 PM
  #53
ScrapMaker's Avatar
luckily I developed a remote system control device for that very reason...
I rotate my key 3 times to run, then pull it out, and my radio comes on. - or I can do it via my 2-way pager remote. I still need to hook up the wire to my dome light so that it stays on until I get out of the car... but I'm lazy... so right now it just stays on for 5 seconds after I kill the ignition... I like it, feels like a new car.
once my battery gets low, it tries to start the car and run it for 20 minutes, to charge the battery, cycle repeats, radio stays on always, doors locked, keys in-hand.
if it can't start the car, (fail-safe trigger--hood, etc,) then it kills the radio after a few minutes of the low battery warning)
but that's old news.
Old Aug 1, 2005 | 07:14 PM
  #54
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yea i remeber reading avout u doin that a while back..... well the most technologically advance thing in my car is prolly my head unit. infact the whole car is bunk for wiring sept the radio which i did mahself
Old Aug 1, 2005 | 11:51 PM
  #55
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
holy crap that's a ton of work :P esspecially teh auto-start to charge the battery :P
Old Aug 2, 2005 | 12:21 PM
  #56
ScrapMaker's Avatar
nah, I just needed to sense the ACC signal, and then the box has two outputs, one to power the radio, and one to ground the remote start, (which also stops the remote start.)
I think the parts are like $30, and it can be installed in like half an hour.
Old Aug 2, 2005 | 08:52 PM
  #57
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yea its not that involved if you plan it out properly on paper first then do it..... just tedious.....
Old Aug 3, 2005 | 10:25 AM
  #58
ScrapMaker's Avatar
don't forget the part where your older brother has advanced knowledge in microcontroller programming
Old Aug 3, 2005 | 06:41 PM
  #59
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
hmmm. but i dont have an older bro... i guess im SOL
Old Aug 4, 2005 | 09:37 AM
  #60
ScrapMaker's Avatar
if anyone ever wanted one of those it would be easy to copy the code over, or make it do anything you wanted... like automate locks/windows/ignition... stuff like that
even easier if you already have remote start, automatic windows(like me,) because then you just tap into the activate wires...
Old Sep 9, 2005 | 10:17 AM
  #61
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Well...thought you guys might want to know what the setup looks like now. Nothing big and the rear sails look like nothing's changed on the outside.
However the fronts do have one noticable difference:
And I have no more spare tire...instead there's this thing in there:
Unfortunately there's some rust that needs to be taken care of down the bottom...but the car is older than me so I'm not too worried.
Old Sep 9, 2005 | 10:34 AM
  #62
ScrapMaker's Avatar
Hrm, I didn't realize the Q-logics had the tweeter up so high, I thought it was at the bottom of the kicks... how does it all sound?
plus you don't have to get rid of the spare tire! just plan it out first!
Old Sep 9, 2005 | 11:30 AM
  #63
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
The thing is...the amp was installed at teh shop, they tried various ways to fit both in there but they simply couldn't do it, it seems.
The Tweeters: It sounds great to me, very clear highs...I think I need some more umph to the bass though. I found a switch in the box for the amp to adjust the bass signal...so when I get brave, I'll wore that up to a blank spot on my dash (looks like buttons could go there but nothing's there right now except rubber :P ). I like the setup as I can hear my music nice and medium-loud inside the car but you can hardly hear it outside the car, even with the t-top off. However, once you open the door or the trunk, the sound comes pouring out. :-P
Old Sep 9, 2005 | 11:43 AM
  #64
ScrapMaker's Avatar
that's good, so the mb quarts are good?
Old Sep 9, 2005 | 01:05 PM
  #65
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
extremely...I'm very happy with the setup and it sounds marvelous to me. Plays my skillet, Audio Adrenaline, and Switchfoot CD's great ^_^
Old Sep 19, 2005 | 09:54 PM
  #66
Red1991TransAm's Avatar
Car: 1991 Red Trans Am
Transmission: 5 spd manual
Wow, I can't believe u scrapped the entire performance audo thing to put in ole 6x9's - woulda personally just replaced the speakers and added a sub ...
upgraded 4x6's would have given u crisp highs while the 4" or 5" subs would have given u nice mid base...
with that said.. its ur car - and now its like everyone else's with the normal setup
Old Sep 20, 2005 | 09:57 AM
  #67
ScrapMaker's Avatar
yup, completely ordinary now...
Old Sep 20, 2005 | 06:29 PM
  #68
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
4x6's are the worst speaker i've ever had the displeasure to work with so far.... the stock ones break up and distort very easily and the highs they produce are high enuff to break glass... putting in the back would only make it so your passengers back there deeloped and ear bleed lol
Old Sep 20, 2005 | 08:13 PM
  #69
I enjoy my kappa 4x6's!!! I just think he should have upgraded the speakers he had there... that would have been cool in my opinion
and thats just it... my opinion!
Old Sep 21, 2005 | 09:18 AM
  #70
ScrapMaker's Avatar
I think the kappa 4x6s would sound amazing in the rear, along with a nice set of midbass drivers, hopefully utilizing the stock ported 'enclosure' that came with the performance sound option...
6x9s really lack midbass, it seems, because it's all converted into rattling metal... maybe it it was sealed up back there... that's why I'm so intrigued by that stock subwoofer setup...
Old Sep 21, 2005 | 09:23 AM
  #71
ScrapMaker's Avatar
Also... if you think the kappas hurt people's ears in the back seat... you have not heard these! the kappas cannot come close to keeping up with how loud and crisp these can go...
When I go to a tailgate party, I fade the deck close to the rear, and crank it... sounds especially amazing with the t-tops off...
I'd roughly estimate that these speakers can take twice the power before they distort, compared to the kappas... I have them wired to a 2 Ohm load right now, which gives them roughly 150... I can pretty much max out the amp and they hardly complain... clearly I never play them that loud, but just for educational purposes...
Old Sep 21, 2005 | 09:35 AM
  #72
ScrapMaker's Avatar
Too bad these enormous magnets are usless... since I can't play bass through these speakers without going insane... I hate rattles... I'm thinking of building spacers for the 6x9s so that air just rushes out the sides, hopefully stopping rattles...
Old Sep 21, 2005 | 09:37 AM
  #73
ScrapMaker's Avatar
btw, that black stuff is liquid-gasket... I put it on so I could hopefully stop some of the rattles... NOPE! Just made me angry as hell... I may remove it, but it's not hurting anything, just making a better seal right now...
Old Sep 21, 2005 | 09:03 PM
  #74
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
damn joe rogan.... those are sexy.. i want some.....lmao
Old Sep 22, 2005 | 09:35 AM
  #75
haha!!
gotta do whatever works
Old Sep 22, 2005 | 10:23 AM
  #76
ScrapMaker's Avatar
joe rogan??
anyways, I almost wish I could mount these 6x9's backwards...
Old Sep 22, 2005 | 11:26 AM
  #77
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
...I almost wish I could mount these 6x9's backwards...
NO.....
Old Sep 22, 2005 | 11:51 AM
  #78
ScrapMaker's Avatar
I forgot to add the following to my previous post
/kidding
//not a r1cer
Old Sep 22, 2005 | 06:52 PM
  #79
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
lol joe rogan from fear factor....
you nkow the Chappelle show when Tyrone Biggums was on fear afctor... lol he was like damn joe rogan... and i call erry1 that noe lol...
Old Sep 22, 2005 | 07:19 PM
  #80
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I can hear the voice now: "...and this is Joe Rogan from MTV's Fear Factor and we're here in search of some beautiful...New York *****!". hehe
Old Sep 23, 2005 | 05:25 PM
  #81
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Sadly I didn't have the budget for them to go in and work on that, nor the know how, confidence, or time (this being my daily driver and well...only car I have right now), to do the setup myself for the 4x6's...
But I enjoy it so that's what counts for now. The 6x9's sound better than the 4x6's+mini-bass setup.
Sorry to disappoint. :P
Old Sep 23, 2005 | 06:56 PM
  #82
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
In responce to the 6x9 rattle. I know what you mean.. the rattle drove me crazy.. that and every time it would actually move air the sail panel area on the outside of the car would move... I just turned off the bass to all 4 speakers and then I run my subs for the bass. Have a Fully amped car is nice that way. every speaker is amplified.. the 4 in the stock location run on a 4x400rms wat amp (100watt rms per speaker.) and then the subs are running 300watts rms each... plenty for my car the way it sits now lol.) I get rattles from the rear (back hatch) and rattles from the front (that screen in the front near the windshield washer arms.. and the wipers themselves)... one day i will figure out how to stop that....
Old Sep 23, 2005 | 10:34 PM
  #83
ScrapMaker's Avatar
uh, I think they call that a 2002 Trans Am WS6
Old Sep 23, 2005 | 10:41 PM
  #84
No thanks. if i wanted to get a car that new i would probably go with something else.. never much liked the 4th gens...
Old Sep 24, 2005 | 10:08 AM
  #85
I'd love to have a 02 WS6 T/A!!!! Will never get rid of my 82 T/A though
Old Sep 24, 2005 | 12:23 PM
  #86
ScrapMaker's Avatar
I guess it's personal preference...
I prefer 320hp, ram air, 4 wheel disc abs, good a/c, non-leaking t-tops, non-rattling panels, and very quiet ride.
also, if you can't get a chick by simply driving one of those, you're doing something VERY wrong.
Old Nov 23, 2005 | 09:00 AM
  #87
Jeffluke's Avatar
Car: 90 L98 IROC/87 LB9 NM5 1AZ / 96 TBI 350 700R4 XCAB S-10..LT1 SOON
Engine: L98/LB9/LT1
Transmission: 700R4/WC-T5
Axle/Gears: 3:73
PERFORMANCE AUDIO
The original performance sterio boxes in the t/a are pretty cool, and are ported, and give you some versitility in the middle of the car, I have a set of them and maybe put my 4/6 infinnity's and a 4-5 in small sub in them, and anybody can put a 6/9 in there, another thing you can do is fiberglass the stock foamy's (6/9 equiped cars) for some better sound.
mud runner
Nov 2, 2015 07:30 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
