pioneer HU technical problem
Old Jul 8, 2005 | 12:29 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i have an older deh-p6000r that i bought new a while ago, a couple years later i'm driving down the road and the whole faceplate will go right out and still play audio, well i turned the key off and the thing was still playing! and it seems while pressing buttons the display will "lock up" just wondering if anyone had this problem or know what it might be, aside from this the stereo is mint and way better then the factory delco
Old Jul 11, 2005 | 09:41 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Could be bad connection to the faceplate, but more then likely it the ribbon cable to the faceplate. Vary common and the symptoms sound right.
Old Jul 12, 2005 | 02:05 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i had a dirt cheap 20W kenwood have almost the SAME issue as you are having, i cleaned the contacts on the HU and faceplate with a q-tip/ cotton swab and rubbing alcohol. for the realy grimed up ones i used a pencil eraser. good as new for about six months, then i had to do it agai, eventualy sold it with the piece of crap car it was in...
Old Jul 12, 2005 | 07:07 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yeah i was thinking that ribbon cable, it's like if you move the face around a bit you can get it to do it, i cleaned the contacts and stuff
Old Jul 13, 2005 | 07:15 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Ribbon cable is vary common in that model.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
