I got a cd player out of my other car...what more do i need to put it in the camaro?
Old Aug 8, 2005 | 08:42 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Hi. I took my cd player out of my civic today. It is an aiwa player. And I wanted to put it in the camaro now. I have a honda mounting kit and wiring harness with it too. Will I need a different wiring harness and mounting kit for this car now? And also, do I even need the mounting kit, or can I just let it sit in there? And finally, do I even need the wiring harness, or can I just solder the wires myself? Also, anything I might not be thinking of, can you please let me know about it. Thanks a lot guys.
Old Aug 8, 2005 | 10:10 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
First off, you need a diff harness connector completely different then the Honda. You could cut into the stock harness but I wouldn't do that. Yes you need a new mounting kit. They sell them at Walmart or Advanced. You could leave it siiting there but it would look kinda half A**. Let me know if you need anything else
Old Aug 9, 2005 | 06:31 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
ya....Use the harness its alot easier. Spring for the dash kit too. Might cost you all of 20.00 for both at walmart.
Old Aug 9, 2005 | 09:11 PM
ZZ4 86 Z28's Avatar
well, ive been looking around and circuit city and best buy want 18 each for the harness and mounting kit. I dont wanna spend 40 bux on this. and its a little less on crutchfield, but then theres shipping, so its like 36 bucks. isnt there anywhere else I can get it cheaper? or maybe both of them together? thanks again.
Old Aug 10, 2005 | 03:25 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
ok, i know everyone is always into doing it right, but you do NOT need a wiring harness adaptor. more then likley your stock harness with GM connector in the camaro is long gone anyway. secondly, your iawa deck does have a harness allready right? if so all you need to do is match the wires on the harness, to the camaro wires. many of them will be the same. red for hot, black for ground. yellow for acc. the harness on the deck should be labled (unless the installer who put it in your civic pulled them off) as far as speaker outputs go. . i am sure you could find a diagram on the forum somwhere that goes over the camaro wiring. and then just hook up the wires coming out of the back of the deck to the wires in the dash. i would recomend soldering if you want a real good quality connection. but if it is just a junky deck with stock speakers (like what i am running right now) you can get away with radio shack crimp connectors.
the dash kid however, you are going to need.
Old Aug 10, 2005 | 06:18 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
walmart should be a bit cheaper.
Old Aug 10, 2005 | 07:18 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
It takes money to do things right. If you can’t spend $35.00, don’t do it, work longer…
Old Aug 10, 2005 | 09:20 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
or you could go to AutoZone or Walmart and get everything you need for under $15....
I wouldn't cut the stock wiring harness when the adapter is like $4.... then the mounting kit is $8-$10
Old Aug 10, 2005 | 11:05 AM
ZZ4 86 Z28's Avatar
well the nearest walmart to me is in like bumble f***, but maybe I'll find the closest Autozone. THanks.
Old Aug 26, 2005 | 12:14 AM
ZZ4 86 Z28's Avatar
OK. My brother went to college today and there was a walmart there. I got the dash kit and the wiring harness. I spent a good 10 minutes wiring it up and getting it on. And first off, I think i need an antenna adapter (although i dont listen to the radio often anyways...especially now that I can play CD's ). But more of a problem, I turned on the ignition, nothing happened for like 10-15 seconds, and then it turned on. It was on for a minute and then shut off. It made the bleep sound that its supposed to make when you turn off the ignition. My "wiring job" was just twisting each seperate connection together, and then covering each one with electrical tape. Could this be the problem? THanks a lot. Also, could it just be one specific connection? Thanks agin.
Old Aug 26, 2005 | 06:33 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
You live in Rockville, how far can the Walmart be?
Old Aug 26, 2005 | 06:36 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
...I spent a good 10 minutes wiring it up and getting it on. ...
...My "wiring job" was just twisting each seperate connection together, and then covering each one with electrical tape. Could this be the problem?...
"twisting each seperate connection together, and then covering each one with electrical tape"
Solder/heat-shrink or crimp.
Old Aug 26, 2005 | 09:47 AM
ZZ4 86 Z28's Avatar
Yea, I didnt have anything else, and it only took like 5 miuntes. I was really anxious to install it. And the nearest walmart is in germantown (like 20-30 minutes away).
Old Aug 26, 2005 | 03:12 PM
ScrapMaker's Avatar
get some crimp-ons... you don't even have a radioshack nearby?
Old Aug 26, 2005 | 10:32 PM
ZZ4 86 Z28's Avatar
Yea i got some of those things. Its all working fine. Thanks for the help.
Old Sep 13, 2005 | 11:08 PM
Syn's Avatar
Syn
Car: 1989 Formula Ws6
Engine: 305 tpi
Transmission: 5speed
is there attena adapters so i can listen to the radio? caus eth stock one won't fit in my cd player
Old Sep 14, 2005 | 09:10 AM
ScrapMaker's Avatar
Try any store that sells car audio stuff.
Old Sep 14, 2005 | 01:46 PM
ZZ4 86 Z28's Avatar
neh, i didnt get an antenna adapter. and in case scrapmaker didnt notice, its already in.
Old Sep 14, 2005 | 02:21 PM
ScrapMaker's Avatar
This post was in response to Syn's post. I don't get what I would or would not notice in this particular case.
Old Sep 14, 2005 | 02:34 PM
Syn's Avatar
Syn
Engine: 305 tpi
i don't know radios at all,and when i put my first one in last time the attena wouldn't plug into the back of my cd player
thanks
Old Sep 14, 2005 | 02:40 PM
ZZ4 86 Z28's Avatar
o..i thought you thought i was still looking for the parts to get it installed. sorry about that.
Old Sep 14, 2005 | 03:44 PM
ScrapMaker's Avatar
thanks
How much did you end up paying for that adapter, Syn?
Old Sep 14, 2005 | 03:52 PM
Syn's Avatar
Syn
Engine: 305 tpi
at the store it was 10 but i didn't buy it cause i wasn't sure if it was what i needed. i'll prolly just buy it and see if thats what i need.
Old Sep 14, 2005 | 03:59 PM
ScrapMaker's Avatar
I think walmart and autozone sell them for like $2.99
Old Sep 14, 2005 | 04:41 PM
Syn's Avatar
Syn
Engine: 305 tpi
wtf i was at walmart last night,maybe it was the wrong thing
Old Sep 15, 2005 | 09:46 AM
ScrapMaker's Avatar
I guess they could have changed the prices, but I think there's only one antenna adapter.
This is the wiring harness AND the antenna adapter
Old Sep 15, 2005 | 11:59 AM
Syn's Avatar
Syn
Engine: 305 tpi
i got the same thing but it says gmo1 up in the left hand corner.
jaridjohn
Jul 8, 2024 03:49 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
