Battery Size??
Old Oct 18, 2005 | 09:31 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Battery Size??
For some of you guys who have read the "Blown Cap??" Tread, I was thinking what if i replaced the battery with a bigger one. Will that stop the Lights from flickering when the bass hits? I know you may think that its a grounding problem but i dont think it is.
Old Oct 19, 2005 | 07:14 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If you're running a 140A Alt. with your amps your lights shouldn't be dimming. Don't just replace the battery, have it load tested, if it's good move on. You engine it's idling at some horrendously low RPM is it? Have you done the big three upgrade yet? That does the trick most of the time. Don't under estimate the cheapness of the stock wiring.
Old Oct 19, 2005 | 11:24 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Well the battery is brand new so i wont worry about that then. No i havent did the big 3 upgrade yet, just trying to trouble shoot everthing before i go ahead and do that. But what if that doesnt fix the problem??
Old Oct 19, 2005 | 12:18 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Worry about it then.
Old Oct 19, 2005 | 01:17 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Johnoooooo
Sep 22, 2015 08:55 AM
Linson
Sep 21, 2015 01:08 PM
m00n420
Sep 11, 2015 02:39 PM
timonator
Sep 10, 2015 07:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
