*NEW* Sony X-Plod Sterio System
Old Oct 10, 2005 | 06:04 PM
BlackMagic's Avatar
Car: 1986 Firebird
*NEW* Sony X-Plod Stereo System
Old Oct 10, 2005 | 09:34 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
You spell "Stereo" wrong.
Nice install, hope the Sonys will hold up for you
Old Oct 10, 2005 | 10:06 PM
BlackMagic's Avatar
Car: 1986 Firebird
I knew that it looked funny....lol
BlackMagic's Avatar
Car: 1986 Firebird
if they dont, i have a three year replacement plan
Old Oct 11, 2005 | 08:42 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The fuse should be near your battery, not the amp. Wiring it that way offers absolutely no protection for the length of wire between the battery and fuse.
Old Oct 11, 2005 | 07:02 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
well unless hes got a fuse near the battery too....Who knows
Old Oct 12, 2005 | 07:42 AM
Jim85IROC's Avatar
Sure, in which case the only damage done is wasting money on a fuse you don't need.
Old Oct 12, 2005 | 07:47 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
Heh, I was about to comment on the fuse location myself.
Though its not where its supposed to be, its sure in an easy place to change!
LOL
Old Oct 12, 2005 | 08:55 PM
xunedeinx's Avatar
Car: 1991 firebird
Engine: V8 305
with those subs and amp, which are sonys btw, id bet you my monthly paycheck that he'll never need a fuse. If the amp says 1000 watts, id lay money that it isnt putting out close to 650. Run some 2 gauge wire and your set.
other then it being sonys, pretty clean install bro.
Old Oct 12, 2005 | 09:03 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
The idea of a fuse as close to your battery as possible is to protect against car fires. If the insulation on the power wire wears through you're looking at a pretty good electrical fire unless there's a fuse on the battery end to stop the arcing.
Old Oct 12, 2005 | 09:06 PM
xunedeinx's Avatar
Car: 1991 firebird
Engine: V8 305
^i know that bro, its supposted to be no more then 18 inches away from the battery. i install this ****. Just saying that the sonys are very underpowered and over-rated, that you almost have no problem to worry bout. You would do it, safty wise, but i doubt that it would make a difference if u didnt have it.
Old Oct 12, 2005 | 09:17 PM
Gummie's Avatar
Car: 88 GTA
No hard feelings, sorry if I came across the wrong way
Still, regardless of the amp on the end of it, any badly routed power cable can wear through.
Is it just me or is that amp overfused? Assuming this is the same amp...
http://sm.crutchfield.com/S-C5I2ljBi...display=XL#Tab
Two 40 amp fuses for a sony?
Either way, welcome to the world of car audio BlackMagic. Your wallet will never be quite the same.
Old Oct 12, 2005 | 09:20 PM
xunedeinx's Avatar
Car: 1991 firebird
Engine: V8 305
LOL, yea, after he gets over his short lived sony fad, which a majority of us have been threw, including I, you wallet will be so much lighter. No more load on your back to deal with!!
And, yes, the 2 40 fuses it comes with are WAY too much, if anything shorted, it wouldnt do a damn thing. When i had my 1200 watt sony amp back in the day, i replaced it with 2 20 fuses.
Old Oct 12, 2005 | 09:58 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Regardless of the power rating of the amp(s), the battery still has several hundred amps at its disposal which can cause quite a bit of heat & possibly a fire if shorted to ground. EVen if you remove the amps from the car, there could still be a fire if there is improper fusing.
Old Oct 12, 2005 | 09:59 PM
xunedeinx's Avatar
Car: 1991 firebird
Engine: V8 305
true that. again, wat i said was just a stupid comment about the crappyness of sonys, no harm takin. made a mistake, its all good.
Old Oct 12, 2005 | 10:17 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
That's cool, man. The danger of a public forum such as this is people can read comments and take them at face value. I try to point out things which someone could take incorrectly. There are a whole lot of people who read and never post here. Glad you didn't take it the wrong way.
Old Oct 12, 2005 | 10:19 PM
xunedeinx's Avatar
Car: 1991 firebird
Engine: V8 305
heh, no problem.
i think if he wants cheap subs, to upgrade from sony to insignia, best buys brand, it is a sub-company of MTX i beleive, it is a lot cheaper, and it looks and sounds better.
Old Oct 13, 2005 | 07:53 AM
Jim85IROC's Avatar
I doubt Insignia is any 1 brand. It's most likely a Best Buy derived name and they have the lowest bidder for each product put their name on it. Most of their audio stuff is chinese made crap.
Old Oct 13, 2005 | 10:51 AM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
I must be missing something because it sounds like alot of people have had trouble with these subs or just dont like them. I've got the same subs with a 1100watt sony amp in my 95 camaro and its sounds great. I mean for how cheap i got the new system for and how it preforms i don't think i could have done any better. I've had mine for a year now and tend to listen to it very loud and have yet to have any kind of trouble. I'll let you know guys know when the trouble begins.
Old Oct 13, 2005 | 11:29 AM
blackroc68's Avatar
sony
i had a sony 100 watt 2 channel amp with pioneer 6by9 speakers and a sony xr-c900 head unit in a k5 blazer. the bass shook the rearveiw mirror. sony products are decent!!
Old Oct 13, 2005 | 01:01 PM
Jim85IROC's Avatar
If you're happy with them, then great. A lot of us have more demanding requirements when it comes to certain products, so the Sony stuff no longer fits our needs.
When you get to the level of "loud" that some of us are at, your subs will go "pop" in a hurry. Likewise, some of us (usually different people than those who want the stuff loud), have more stringent taste when it comes to sound quality, so once again, the Sonys no longer stand up.
Old Oct 13, 2005 | 03:31 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Nice, vary P.C. ...
Old Oct 13, 2005 | 04:38 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
and true!
Old Oct 13, 2005 | 08:56 PM
Jim85IROC's Avatar
Originally posted by NEEDAZ
Nice, vary P.C. ...
I was in a good mood this morning.
Old Oct 14, 2005 | 07:52 AM
blackroc68's Avatar
I would put my sony xr-c900 up against my kenwood any day. volume wise and sound quality wise.
Old Oct 18, 2005 | 02:14 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I'll put my Pioneer against every other Headunit i've come into contact with to this date... lol
Old Oct 18, 2005 | 03:01 PM
Jim85IROC's Avatar
You have something from the pre- X-plod era. Big difference.
Old Oct 18, 2005 | 05:36 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
i have had quite a bit of sony products and frankly people say that there stuff is garbage i have had many sony amps and head units and never had one thing go wrong never had a skip or any thing
Old Oct 18, 2005 | 07:01 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
its a matter a of personal preference i suppose....
my audiobahn system was pretty mean b4 i got jacked..... but then again thats my take on things
Old Oct 19, 2005 | 05:06 PM
blackroc68's Avatar
Sony was my favorite brand of equipment before that ugly red xplode stuff !! !! who would want a red and silver head unit? Not fond of red subwoofer either. polk momo are funnylooking also. sound ok!@~!
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
