how to use amp settings
Old Dec 30, 2005 | 01:19 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
i.e. variable crossover (lpf, hpf, full) and gain
I have 1 x 12 in sub and a 400 watt amp in the trunk
Old Dec 30, 2005 | 01:46 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Gain = the amp's volume more or less. You set it in relation to your deck so that the amp won't max out before the HU is all the way up. Search and you will find a ton of articles about setting gains.
LP/HP = low pass or high pass filter. Lowpass cuts off higher frequencies after a given point (for subwoofer applications), Highpass cuts off low frequencies below a given point (for speaker applications), and flat amplifies everything. The 'variable crossover' is the point at which you want your LP/HP filter to take effect. It serves no function if you have the amp's crossover set to full.
Old Dec 30, 2005 | 02:46 PM
very helpful! thanks alot.
RazorN8
Jan 7, 2022 11:44 AM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
