Pioneer Stereo gets hot
Old Feb 16, 2006 | 12:27 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
Has anyone else had this problem. This only happends when the car is running. My stereo Pioneer CD player shuts of within 45 minutes of driving. It says HEAT, and won't play the CD anymore, but will play the radio. My old CD player worked fine and never had that problem. I know it get warm where the deck is located above the transmission. I tried the insalate it better, but no luck there. I think my pioneer is to sensitive, but I'm not sure.
Old Feb 16, 2006 | 12:45 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Need the model # (and serial # if you can) off the radio.
Old Feb 16, 2006 | 03:19 PM
magadith's Avatar
Engine: 305 4bbl
Pioneer DEH-P5200
Old Feb 17, 2006 | 06:22 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Well, First thing to do any time you have a over temp problem is check the speakers. Ohm them out and see that they are all over 3 ohms (should be 4 ohms but never are for several reasons). Also check the ground. If that all checks out it's probably a bad thermistor (temp sensor) in the HU or bad connections at the microprocessor. Not common but happens. It's fixable, but you'll have to decide if you what to spend the money on it. It is a mid-level couple year old unit after all. To bad you're on the wrong side of the country.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
meeklay812
Oct 1, 2015 03:46 PM
ironbmt
Sep 27, 2015 06:00 AM
