question about dist. blocks for power wires
Old Mar 12, 2006 | 03:07 PM
BOTTLEDZ28's Avatar
Transmission: A4
I need to run two amps and I have about 25ft of 2 gauge welding wire to run from the battery to a dist. block. One of the amps(sub amp) has a huge terminal input for the power, something like 2-4 gauge. the other amp(for components) has a smaller terminal, something like 8-10 gauge. I was hoping to run 4 gauge wire from the dist block to both amps but I dont htink I will be able to fit that wire into one of the amps. My question is, is there any dist blocks out there that have something like a 2 gauge input and 4 gauge and 8 gauge output? All the ones I have seen are 4 gauge in and 8 gauge out. I have looked over at partsexpress.com but there is nothing there that I can use. Is there something I can pick up at an electrical store. it doesnt have to be pretty cux its getting hidden in the sail panel where the back speakers use to be. I just need something that works w/o jerry rigging it.
the amps I am using are Kicker KX600.1 and 250.2
Old Mar 12, 2006 | 05:14 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Here are a few:
http://www.crutchfield.com/S-k38XySG...15&I=211FBR24A
http://www.sjgreatdeals.com/sisp48fd2i.html
http://www.darvex.com/miva/merchant....t_Code=S2064IE
http://www.cardomain.com/item/STISFPD2ANL
It depends on if you want a fused block or not. I personally would get a fused one for peace of mind.
I found quite a few on ebay as well:
Ebay Search Results
Hope that helps.
Old Mar 12, 2006 | 06:08 PM
BOTTLEDZ28's Avatar
Transmission: A4
thank you. quick question though, is it better to add an inline fuse near the battery and not get a fused dist block, or not put an inline fuse and instead get a fused dist block?
Old Mar 13, 2006 | 12:21 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
run a big fuse under the hood by the battery and run a fused distribution block in the back as well.
Old Mar 13, 2006 | 12:44 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
The under hood fuse is far more important in my eyes. Fusing by the amps really isn't a necessity unless you don't want to ever pop an amp's fuses, which is a pretty hard feat to accomplish most of the time anyway. The under hood fuse just might save you from a car fire though.
A note on distro blocks: I’m running 2 gauge wire and am using a 0/1 in and 4 gauge out. It’s working/holding up fine.
Old Mar 13, 2006 | 07:27 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
^^^ What he said. You NEED the fuse under the hood.
Old Mar 13, 2006 | 05:37 PM
BOTTLEDZ28's Avatar
Transmission: A4
Sounds good. Now as for fuse rating, I just need to add the value of the 2 fuses in the amps and that is the fuse I need under the hood right?
Old Mar 13, 2006 | 07:27 PM
Gummie's Avatar
Car: 88 GTA
As long as it doesn't exceed what the wire is capeable of moving, you're correct.
http://www.bcae1.com/wire.htm
Old Mar 24, 2006 | 08:59 PM
digitmachine's Avatar
Car: 1988 Formula Firebird - Red
Engine: 305 tbi
Transmission: th700r4
Stinger makes an adaptor that will let a 4ga wire go in an 8ga hole. The part number is S48ADAPT
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
