Custom boxes
Old Mar 19, 2006 | 07:19 PM
EthanH's Avatar
Custom boxes
I want to put some woofers in, but cant find the right box. I need my trunk space, but then again thats were i want them. Got any ideas? Post some pictures, heres the best i've seen
Old Mar 19, 2006 | 10:09 PM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
Here is what mine looks like. There is a 10" Alumapro sub in a sealed box under the amp cover. Still gives me some room to store stuff, plus the sound i'm looking for. Hope that helps.
Ryan
Old Mar 20, 2006 | 03:36 PM
EthanH's Avatar
I like the set up but i think id rather see the sub.
Old Mar 20, 2006 | 07:14 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
The problem with being able to see the sub is that it means whatever you surface you build into you won't be able to put stuff on for fear of damaging the driver. This means you loose the whole well if you end up with a well box.
You're either going to have to give up the well to your subs (if you want them showing), build a box like IROC350TPI's (nice box btw), or build a stealth enclosure, which is a lot of work. Stealth enclosure = turning the airspace behind your plastic trim in your hatch into a giant box. Lots of fiberglass work, which means a lot of time invested. It’s defiantly a few steps above my box build and I’ve already got a good 10-15 hours into mine.
Old Mar 20, 2006 | 07:59 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
i still have room for the ttops if i put them in upside down they dont poke anything. any grocerys and stuff goes in the back seat...what do any of us really carry anyhow....me not much!
Old Mar 20, 2006 | 08:04 PM
mgomez's Avatar
Car: '88 Trans Am/'96 Trans Am
Engine: L98/LT1
Transmission: 700R-4/T-56
Axle/Gears: 3.42/4.10
IROC350TPI, I really like your design. I was wondering if you would be willing to share it. I need something similar in my ride. I think it would be perfect. If you could post or p.m. me the dimensions and materials I would much appreciate it.
Old Mar 20, 2006 | 08:06 PM
EthanH's Avatar
Gummie have you ever thought about speaker covers on top of them? Then you can still see your speaker without the fear of damaging it.
Old Mar 20, 2006 | 08:12 PM
EthanH's Avatar
jcurrieirocz I like your design. The diamond plate looks pretty cool. Also what kind of material is your speakers sitting in?
Old Mar 20, 2006 | 09:07 PM
Car: '81 Trans Am
Engine: 6.6L
the meaterial around them is vinal (pleather) type stuff wraped over foam and its a faseplate type thing with the subs mounted in a fiberglass box
Old Mar 21, 2006 | 12:41 PM
Gummie's Avatar
Car: 88 GTA
Yeah but most grills are not strong enough to have stuff put on top of them and are more for aesthetics than anything else. If you manage to find a grill that’s strong enough to have stuff put on top of it you’re probably going to end up scratching the hell out of it.
Old Mar 22, 2006 | 12:00 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Subs
JCurrie I love the box where did you get it or was it custom... please let me know thanks.....
Old Apr 1, 2006 | 07:53 PM
Car: '81 Trans Am
Engine: 6.6L
I built it all...cheack out my web site for more building pics
HP52TA
Feb 3, 2018 10:51 PM
bubbaz28
Sep 18, 2015 02:09 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
