Fiberglass Kick Panels???
Old Mar 21, 2006 | 06:13 PM
1992rallysport's Avatar
Car: 1992 Camaro RS
Engine: Head Cam LS1
Transmission: T56'er
Axle/Gears: 4:10'ers
Hello,
I have been in and out of the third gen boards and a while back a few people made fibergass kick panels. Does anyone make these anymore or am I on my own to make some. If so does anybody have links or pictures on how they went about to make them. Thanks Chris
Old Mar 21, 2006 | 09:07 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I still make them. I'm building 2 pairs now, and in a week or two I've got another pair to build. If you're interested in a pair, give me a PM or an email and we can chat.
Old Mar 21, 2006 | 10:04 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I'm running Jim's kicks because I love the way they look and because Jim makes good stuff. It was also nice to not have to worry about aiming all the drivers. If you’re feeling cheap you can make them yourself for well under $50 in materials. All it requires is some wooden rings to hold the woofers and tweeters, some fleece or an old t-shirt, and some resin. Granted, that is oversimplifying it a bit
Old Mar 22, 2006 | 05:04 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
anybody got any pics of these or some pricing guidlines?
Old Mar 22, 2006 | 08:06 PM
Jim85IROC's Avatar
I've got pics and pricing on my website:
http://www.iroczone.com/jim/motorsports.htm
Old Mar 25, 2006 | 12:04 AM
ColdGTA's Avatar
Car: 1988 GTA
Engine: 5.7L stock
Wow Jim nice kicks. I run CDT's as well. I'm curious, the kicks in the pictures are the 6"? Do you aim the woofer at all or just mount it flat? How about the tweeter. Do you aim up to the upper interior? I run a set of the Q-logics that I reinforced with fiberglass and sound deadener. I must say that with that and adding some polyfill in the kicks that sound is amazing. I ask about the angles because the Q-logic kicks have the woofer and tweeter angled up some. I really don't like the position they chose for the woofer and If I were to make some I would have done like you did and put it further back. I want to make a set for my 2nd gen T/A but the space is limited in the kicks. Mounting the woofer in the kick somewhat flat would really make the install much easier. I just wonder about how the sound would be as long as I could get the tweeter aimed decent.
Old Mar 25, 2006 | 07:58 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I actually just made a set a few days ago... I'll go clean the car and get some pics of for you guys...
Old Mar 25, 2006 | 10:34 AM
jimp2001's Avatar
Engine: LO3 305 TBI
My kick panels are a sealed enclosure that screws to the existing kick panel. It took 4 hours to fabricate, I let it cure overnight, and the next morning I carpeted them and installed them. I'm using a set of 5.25" Zapco components, and my crossovers are mounted under the dashpad where the stock 4x6's were.
Pics as promised...
Old Mar 30, 2006 | 02:25 PM
ColdGTA's Avatar
Car: 1988 GTA
Engine: 5.7L stock
TTT!
Old Mar 30, 2006 | 02:42 PM
Jim85IROC's Avatar
The speakers in the pic are 6.5" CDTs. I'm actually building another set now with the exact same components. The drivers are aimed toward the center of the car to an extent, but not a ton. I'd say they're aimed at approximately 15 degrees. I'm really not impressed with CDT's lack of a swivel cup in their flush mount tweeters, especially because their design sets the tweeter back a mile in the cup. However... I'm not a huge believer that tweeter aiming is as critical as people hype it up to be. There is so much reflection in the foot well, that your high frequency imaging changes very little no matter how you aim your tweeters. In my old design, one of my tweeters wasn't even visible because it was obscured by the underside of the dash panel. In experiments, I've moved the tweeters all over the place. Yes, there's an audible difference, but it's much less noticable than I ever imagined it would be.
Here's what my most recent pair with those components looks like:
Old Mar 30, 2006 | 02:48 PM
ColdGTA's Avatar
Car: 1988 GTA
Engine: 5.7L stock
Thanks Jim. Nice set up. Glad you got the 6.5 drivers to work. I was always under the impression that the CDT 6.5 drivers needed alot of air space.
Old Mar 30, 2006 | 05:44 PM
jimp2001's Avatar
Engine: LO3 305 TBI
I'll take pics of my co-worker's '83 T/A Pace Car tomorrow. We did 6.5" components in the kicks and 8" mids in the doors.
Old Mar 30, 2006 | 09:01 PM
Jim85IROC's Avatar
why 6.5s if you used 8s in the doors? You could have gotten the better off axis capabilities and smaller packaging for better aiming with a 4" woofer as long as you had the 8s to do the midbass duties.
Old Mar 30, 2006 | 09:19 PM
jimp2001's Avatar
Engine: LO3 305 TBI
It's an SQ car, strictly goes to shows, rarely driven on road. The system is 5 or 6 years old now, but still sounds amazing.
Old Mar 30, 2006 | 09:25 PM
Gummie's Avatar
Car: 88 GTA
The kicks are not sealed - they vent through a hole in the box. I say vent so that no one will think they're ported (that would be next to impossible to pull off with the extremely limited volume involved). It's just a big hole in the back of the plastic. This is more or less ideal because components are designed to be installed in doors. If the doors aren't sealed up with lots of deadening mat that means the speakers are running more or less infinite baffle, much like they do in Jim's kicks. If the doors are 'sealed' it's still too large (and leaky) of a 'box' to exert much of any kind of force on the driver so it's still running more or less IB.
lots of pictures
(Files titled finishedxxx are of my set as are the in progress pictures. The rest are another set Jim built for someone)
These things can hold some pretty large speakers. I'm running MB Quart QSD-216's in them. There's nothing exceptional about the woofer's size (6.5") but the surface mounting ring requires a 7" hole and is it's self 7.75" across. I think it looks really nice installed. I’m not really a fan of the CDT style grill that just ends with the speaker. The tweeters are flush mounted and there's room to spare there too. The only problem that I can see anyone run into is trying to install a speaker that’s too deep. Sure it can stick out of the hole in the back of the kick but there’s only so much room between the back of the plastic and the metal wall of the car.
I also love the way these sound but you can read about that here
Old Mar 31, 2006 | 02:55 AM
ColdGTA's Avatar
Car: 1988 GTA
Engine: 5.7L stock
Ok now I see. Well to tell you the truth a hole in the back works to my advantage since my install will be in a second gen. Right in the kick area there is a hole which is used for ventilation/AC. Kind of in the cowl area. So now that I have an idea of what's up I know what to do. Thanks. I'll post some pics when I get to them.
Old Mar 31, 2006 | 05:57 PM
jimp2001's Avatar
Engine: LO3 305 TBI
He didn't bring his car to work today... I left my camera at work so I'll post pics next time it's there.
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
tattmann
Sep 27, 2015 05:20 PM
