where do you run the power through?
Old Mar 23, 2006 | 10:21 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
I was wondering where you guys are running the power wire through. Are you opening up a new whole or using an existing grommet? I opened up a new whole next to where all the wires go trough that whole in the passenger side.
Old Mar 23, 2006 | 04:38 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
That's were I ran my 4 gauge power through. Passanger side back firewall/floor board. Runs right down the side up the back behind the plastic and out under enclosure.
Last edited by Rally Smith; Mar 23, 2006 at 04:42 PM. Reason: Automerged Doublepost
Old Mar 23, 2006 | 07:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
ON cars with a passenger side battery, I run all cables through the kick panel near the antenna hole. I find this to be by far the easiest location.
On cars with the battery on the driver side, I run it through a spot under the clutch master cylinder, or on automatics, the spot that would have been occupied by the clutch master cylinder.
Old Mar 24, 2006 | 10:06 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Are you having to cut a new whole or is there a factory grommet there?
Old Mar 24, 2006 | 10:20 AM
Jim85IROC's Avatar
I always cut a new hole. Anything bigger than 8 AWG isn't going to fit real well through any existing holes.
If you've got 8 gauge, you can easily poke a hole through the antenna grommet in the kick panel, or through pretty much any existing hole in the firewall. With 4 AWG and larger, you're better off with a new hole.
Old Mar 24, 2006 | 10:28 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
I'm just running one amp so i think 8g is all i need.
Old Mar 24, 2006 | 08:32 PM
Code's Avatar
Car: 1989 Black Pontiac Firebird
Engine: 2.8l V6
Transmission: Automatic
Axle/Gears: Stock Crap
Depends on your wattage and current drain.... 4 to be safe... AND do not forget to MAKE a GOOD ground connection.....Oh the HORROR of a bad GROUND!!!!!
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
