Bose Kickpanels
Old Apr 8, 2006 | 07:49 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Bose Kickpanels
Just scored a pair of black factory GM Bose kickpanels today. I was going to save up and pay $200 for a set of custom kicks that would fit a 6.5" component setup, but these were WAAAAY more in my budget at the moment to try out and see how they work.
My first question is whether any of you have any experience with these, specifically with installing aftermarket speakers in them. I believe the size is 4", but I am guessing that some 4" speakers might fit better than others based on height and location of the mounting tabs.
My second question is whether I should use this in combination with my dash 4x6 speakers, or in place of?
Oh, and yes, I will be covering them in vinyl or carpet, not leaving them with the old glue showing as they are now!
Thanks in advance.
Old Apr 8, 2006 | 10:42 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I got some BOSE kicks and used them as a template to build my own out of wood and they hold a 6.5". The plastic will be hard to modify but not impossible. However making a panel the same size out of wood would be easier IMO.
Dont use the 4x6s with the kick panels.
Old Apr 9, 2006 | 08:11 AM
Bull's Avatar
Engine: LT1; None
Sounds possibly beyond my meagre abilities...I'm not really a skilled woodworker. Any pics? Difficulty level?
Old Apr 11, 2006 | 03:38 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
TRY LOOKING FOR A PAIR OF Q-FORMS FOR A F-BODY, I LIKE MY SET, YOU CAN GET A 6.5 COMPONET IN THESE
Old Apr 11, 2006 | 09:51 PM
chads89ta's Avatar
Engine: 305 tpi
Transmission: t-5
bull you have a pm
Old Apr 12, 2006 | 12:33 AM
No pics of how they are assembled but all i used to make them were some fiberboard, a jig saw and drill.
Old Apr 12, 2006 | 12:03 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
If you do a search to find people's opinions you will see that while they do work Q-Forms are generally looked down upon because they're cheaply made and don't match the interior very well.
Old Apr 12, 2006 | 03:14 PM
chads89ta's Avatar
Engine: 305 tpi
Transmission: t-5
q-forms
put dynamat behind them, and vinyl dye works well, i have had mine for about 8 years
1992Z28!
Nov 19, 2015 07:33 AM
scottmoyer
Sep 7, 2015 07:06 PM
DJSexay
Car Audio
31
Aug 17, 2001 11:44 AM
