easy stereo install question
Old Apr 11, 2006 | 04:41 PM
transam84's Avatar
I have an Alpine cd/MP3 player CDE-9845. I have all the wires hooked up but 2. I have one blue and white wire that is for the "remote turn-on lead" is this wire for the amp??? if not what do I hook that one to. the other wire is a bigger yellow wire, this one is "Battery Lead". can I just hook this one to a spot on the fuse panel that says battery??? I assume this is for the memory? thanks in advance for any help guys!!!!!!!
buy the way this is going into an 83 Trans Am.
Old Apr 11, 2006 | 05:55 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Blue/white wire, most often referred to as the 'remote' wire does the duty of turning off/on your amps when the deck goes on or off.
The yellow wire goes to a constant +12v source, this has to have power even when the car is off or you will be resetting your clock every time you get in... Just make sure the red wire is to a switched source so the deck will turn off with the car!
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
