proformance sound
Old Apr 25, 2006 | 10:35 PM
jetin85's Avatar
Car: 85 TRANS AM WS6
Engine: rebuilt 350
proformance sound
Where can i find original proformance sound subwoofer speakers for my 85 TA? Where is the amp located in the car?
Old Apr 26, 2006 | 08:40 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
id say your best bet for original speakers is the junk yard, because i doubt dealerships and stores are gonna stock them. The amp is located underneath the passenger side dash panel
Old Apr 27, 2006 | 12:49 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
more specifically the amp is to the left of your cruise control module. the cruise control module is the one labled "AC".
Old Apr 29, 2006 | 10:27 PM
well i kno its sumwhere in that region that i circled.. but idont have cruise... so are their any markings on the amp to indicate what it is?
Old May 1, 2006 | 06:58 PM
Xophertony's Avatar
Axle/Gears: n/a
no. it is the farthest thing on the left under tha passanger hush pannel. it will be plain steel and will have a big connector on the top with the following wire collors:
lt blue/black
drk blue/wht
black
pink
white
purple
red
ltblue
drkblue
this connection will be at the top of the unit and NOT VISABLE with the hush pannel removed, you will need to pull the unit and allow it to hang by the connector in order to see it. this unit is about 6"X6"X1" if that helps. it is the smallest "amplifier" i have ever seen.if you are still unable to find it i can go snap a picture...
EDIT*well i found a picture of the area, i took the image of my 86 that did not have UQ7 and edited it to explain. here it is:
Old May 1, 2006 | 10:25 PM
ahhhh... ok will this gives me a good fuzy on the location so i can go hunting and pull exactly waht i need.. thanks tony
Old May 1, 2006 | 11:00 PM
Xophertony's Avatar
Axle/Gears: n/a
trying to hunt it down in wrecking yards or pulling yours out? if you are pulling yours i would not mind having another dash mounted "gain" control switch
Old May 2, 2006 | 07:34 PM
Well, i am gonna go to scrap yards and sniff around for a bird with the performance sound... i went last year and found a one that had it but backed out bc i only had like 25 bucks on me so i jus bought the gain switch instead lol its jus sittin in my tool box now..
Old May 3, 2006 | 10:23 PM
Xophertony's Avatar
Axle/Gears: n/a
before you install it test it with an ohm meter. (it is a variable resistance curcuit) to make sure the resistance is a nice gentle steping up and down, without any flatspots or jumps/drops. mine is shot, but i ordered another from houseofcamaro.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
