Need help picking out subs
Old Jun 26, 2006 | 10:04 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I have plans to get a box for the rear well. The "bottom" part of the box is 26wx13hx11d and the top part of the box measures 40wx4.25hx15.5d (internal measurements). My amp is a rockford fosgate 2 channel 600W amp. What subs should I get and how should I wire them up to the amp? The box has holes for 10in subs.
Like this
Or get 2 4ohm subs and wire them to each channel of the amp seperatly?
And I'm on a tight budget, so money is a factor.
Old Jun 27, 2006 | 01:09 AM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
what the rms of your amp?cuz im thinking a set of kicker will do
Old Jun 27, 2006 | 09:44 AM
krisb410's Avatar
RMS for model 201S
At 4 Ohms 50x2, at 2 Ohms 100x2, or at 4 Ohms 200x1
Here's the amp specs Rockford Fosgate amp model 201S
According to my calculations, the box is @ 2.8 cu feet.
Old Jun 27, 2006 | 09:50 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That's a very small amp for subs. If you want to get any kind of output at all, you'll need to try to find a sub with a high sensitivity, which will pretty much rule out every high-escursion sub on the market, which unfortunately, is almost all of them these days.
The sub that comes to mind is the old Cerwin Vega "Vega" series, but those haven't been sold in a few years. If you can find a nice used one, and if you've got the room for the massive ported box it requires, that would be your ticket.
In any case, while you're doing your search, pay attention to the rated sensitivity of the drivers. You should be looking for a 90dB or higher sensitivity rating, but keep in mind also that most of the newer subs that have resonable sensitivity achieve it in a large ported enclosure.
Old Jun 27, 2006 | 11:44 AM
krisb410's Avatar
Well right now that amp is bridged and hooked up to a single 10in fosgate sub in a truck style box that sits in the well. And it really thumps hard. I have the opportunity to get a box the will fit into the rear well flush, and holds two 10in subs. I guess what I should have asked is should I just keep my current setup that I am happy with, or should I get the box that sits flush in the well and get two 10in subs that will work with my current amp. Just to piont something out, I only have 4.25 in depth for the subs.
RedLeader289
May 28, 2019 01:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91 SrS
Oct 7, 2015 04:32 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
