Replacement antenna
Old Jul 19, 2006 | 08:52 PM
jojo9722's Avatar
Replacement antenna
I need to replace my antenna on my 1992 Camaro Convertible. My local dealer gave me part #15087886. When I got home and looked at it, it is the newer type with the spiral wire along the entire mast. Is this the only factory antenna available or did my dealer give me the wrong year?
Old Jul 26, 2006 | 10:52 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I would say forget the factory antenna, this is what I did with mine. It looks much cleaner now and get better radio reception. 14'' Whip antenna, 8 bucks at any auto parts store.
Old Jul 27, 2006 | 01:51 PM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
got one
do you need the whole thing or just the top, i have both a cable and antenna, the antenna is a straight style i was going to throw it out, you can have both peices for the cost of shipping , 6-7 $ let me know tsh7822@rit.edu if you want it
Old Jul 27, 2006 | 02:29 PM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
The standard mast is the same for hundreds of different GM cars. In the mid-90's GM upgraded the mast to include the 'spiral wire'. This deflects the wind rushing around the mast while you're going down the road. People used to complain about a constant whistling noise caused by the smooth antenna mast. So, GM fixed it. It works perfectly. No more whistling. They gave you the correct antenna. It is just an updated design. The mast can be interchanged with many, many other cars.
Old Jul 29, 2006 | 12:02 PM
jojo9722's Avatar
I have never had any whistling sound with my original antenna. I don't like the look of the new style as the base is a little different as well as the spiral wire. I wanted to stay with the original look. Thanks for the info, Joe
Old Jul 29, 2006 | 01:53 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what brand and what store are those ?
more info ?
thanks
Old Jul 29, 2006 | 08:01 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
The older GM antenna that your looking for can easily be found at your nearest pick-ur-part (auto wrecker). As mentioned above, they used that same antenna on many, many models. Just bring a wrench and choose the one that's exactly what you want, and for a lot cheaper than what the dealer wants. Take 2 and have a spare.
Old Jul 29, 2006 | 09:19 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
Your best bet is to rebuild the antenna,by just replaceing the plastic guide that runs it.{if it will not move up and down}.Its not that hard ,by just drilling out some of the rivets and getting to the cable you should be able to make it function again.
Old Jul 30, 2006 | 12:34 AM
Axle/Gears: 3.08
I don't think he's dealing with a power antenna. It's just a regular mast antenna.
Old Aug 1, 2006 | 03:00 PM
The antenna on my car is just a generic "whip antenna" Just go to advance auto and look at the stereo stuff, theres like 100 of them just sitting there.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
