kicker L7 15"
Old Jul 30, 2006 | 10:34 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
kicker L7 15"
so do you guys have any ideas how i can make that fit in there nice and snug?? thanks!
Old Jul 30, 2006 | 12:07 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
sledgehammer.
Old Jul 30, 2006 | 12:14 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
its going to be hard with the depth so the box will have to be tall. you could try and angle it facing the front it helps a bit. you might be able to squeeze it in the center area but the sides have more room. itd be easier to fit with a plate or taller box than i had. good luck
Old Jul 30, 2006 | 12:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
i'm trying to fiberglass a box for this. It's kinda on hold for now. 80% done or so. I just wanted to subscribe to this thread to see if anyone else has made one fit yet.
I was thinking of angling it somehow, but it's so deep that once you angle it, it'll hit the hump, like the higher part... tricky.
anyway, let me know what you come up with.
Old Jul 30, 2006 | 02:51 PM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
i had to angle mine when i put mine in because i have 2 12" audiobahn flame q (aw1206t) subs and when i used the parameters for the well box my magnet hit.. so i think i raised the back side of the box about 6 inches or so which i think is the max before you run out of room because of the hatch... id say your best bet would be on the sides also because even with the angle i dont think a 15 will fit in the middle
if you dont need your rear seats you could delete them and have plenty of room for 3 of them
good luck and happy booming
Old Jul 30, 2006 | 07:24 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
yeah i kinda need my rear seats my original idea was to make it facing the glass the box running from the back of the back seats to the hatch part and possibly dropping down into the well for more air space..and then id still need to think of where to put my ports i planned on using tubes thanks for all the input
Old Aug 21, 2006 | 01:16 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
alright ladies and gentlemen...i finished my box tonight....i ended up going 40 inches wide 18 deep and 10 high...havent put it in yet therefor my amp will be here tomorrow...ill try to get some pictures for ya to drool over ...and of course ill let you know how it sounds....and what breaks first..:S
Old Aug 21, 2006 | 11:36 AM
Engine: LO3
awesome just wait for the taillight bulbs to break then its a PITA to change.
Old Aug 21, 2006 | 03:18 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
ive taken those taillights out before...not too bad...but my brand new amp i got today was DOA...called the people back and they said send it back and we will get you a new one.....im pissed..but happy..
Old Aug 21, 2006 | 09:05 PM
Engine: LO3
good customer service. good luck with all that but i just hate have to remove my box when i have to change a taillight which i did last weekend took longer than it shouldve but thats ok at least i wont get pulled over now.
Old Aug 21, 2006 | 09:08 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
yeah...everybody i've talked to doesnt know whats wrong with the amp...its weird..even hooked it up to a friends set up....same thing!
Old Aug 22, 2006 | 10:09 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
any pictures yet?
Old Aug 22, 2006 | 10:14 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
sorry...not yet..because of that ordeal it has pissed me off to much to even want to take pictures...and id rather have the amp in the pic too...as soon as i get it back...pics will be up!!
