no sound
Old Aug 30, 2006 | 08:45 PM
redhotl1's Avatar
no sound
installed my old system out of my 96 into my 89 formulanow i get no sound throught my rca wires i have two amps 1 a 4-channel for mids and highs and 1 bass amp. ican hookup a speaker to the speaker outputs on the radio and get sound but none out of the amps. i tried 2 different sets of rca wires still nothing but when i move the wires around i get a little fuz but only for a second so what to do now???
Old Aug 31, 2006 | 10:35 PM
thaforce's Avatar
Car: '91 Z-28 Hardtop
Engine: 5.7L TPI L98
What kind of headunit? does it have a mute option? possibly accidentally wired the cellphone mute option? it will be hard to tell without seeing it.
Old Sep 1, 2006 | 08:55 AM
redhotl1's Avatar
i have the pioneer unit that is made to fit the factory hole i think its the deh-780 but i`m leaveing in a minute to go the the stereo shop i bought it from and let them look at it
Old Sep 1, 2006 | 05:27 PM
redhotl1's Avatar
problem found radio bad no signal coming out of the rca plug shorted
Old Sep 1, 2006 | 05:28 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
On Pioneers, it's easy to accidentally blow your RCA fuse because of improper grounding... is that what happened?
Old Sep 1, 2006 | 06:36 PM
redhotl1's Avatar
yeah i was having a ground issue during install the radio would come on and off several times before i found the ground was bad oh yell now i need to find a replacement for it
Old Sep 2, 2006 | 10:22 AM
ScrapMaker's Avatar
So it's the RCA fuse? That has to be professionally serviced...
or you could just use a nice littl' work around (with sneaky bri-ish accent)
just get a wire, attach one end to the chassis of your headunit somewhere, (a ground,) and the other end needs to touch ONE (or all, it makes no difference,) of the OUTSIDE metal parts of the rca... so the easiest way to do this is to just un-connect the RCA and stick part of the wire in there, then jam it back on... don't let the wire touch to the inside metal tip, because that's your actual signal, not the ground...
good luck, but if you're having the problem I think you are, this should solve it for nearly free...
Old Sep 6, 2006 | 11:31 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
The old Pioneer 1.5 DIN units had problems with bad solder connections at the RCA jacks. Technically an open, not a short . Probably not the fuse if wiggling things changed things. Vary fixable.
Old Sep 7, 2006 | 05:38 AM
ScrapMaker's Avatar
oh he made it sound like it was an RCA fuse instead... not sure anymore...
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
