Stereo Static
Old Oct 17, 2006 | 08:54 AM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Stereo Static
Specs: 1991 camaro RS 3.1l V6 w ith factory speakers and a generic aftermarket CD head unit.
Problem: When the car is in the accessory switch my stereo sounds perfect. After starting the car and letting it run for about 30sec my audio quality goes to crap. The sound the speakers make is similar to a blown speaker but I know they aren't blown because they are fine when the car is in accessory mode. I already pulled the headunit and rewired the harness and what not so everything there is fine.
Any help is appreciated!
~Austin
Old Oct 17, 2006 | 05:02 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
That's odd. What's the make and model of the HU? How do you have the HU grounded? Are you running amps?
Old Oct 18, 2006 | 12:29 PM
draco's Avatar
Engine: 5.0l TBI
The Head unit is some off-brand walmart P.O.S., thats the best i can tell you. There are no amps and the stereo is grounded by the main black wire on the harness. I've heard that the actual casing of the stereo has to be grounded too, is this true?
Old Oct 20, 2006 | 08:44 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Do you have an ohm meter? If so check the resistance of all the speakers and post back what you get.
Old Oct 25, 2006 | 01:41 PM
teamcamaro's Avatar
Transmission: t-5
i had this same problem with my camaro. the only difference is, i have an amp running my speakers. these r the steps id take to eliminate any static, because obviously something is shorting out when the car is running. i dont know how in depth u want to get to fix this problem but i will list everything.
1. rfi eliminating plug wires.
2. power for headunit coming straight from battery.(reason being that sometimes the stock power line can b shorting somewhere along its path)
3. ground the headunit right to the chasis.(also make sure ur chasis is not picking up a current with voltmeter..another way to find something is shorting)
4. run wires straight from headunit to speakers, that way u know where is no shorts that could be possible from stock wires.
5. check to make sure engine is grounded properly
its a real pain in the ***, u can be glad u dont hav tons of money tied into this or u would really want to shoot urself in the foot.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
meeklay812
Oct 1, 2015 03:46 PM
