Help me prove someone wrong.
Old Oct 26, 2006 | 05:13 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
My friend seems to think that you could blow a rockford fosgate punch p3 by hooking it up to a house stereo. He says that if you hook any car audio speaker to a house audio amp, you could blow it VERY easily.
A speaker is a ******* speaker, the signal that the speaker recieves is 100% universal across platforms.
The punch p3 is a dual voice coil subwoofer, so IF ANYTHING, I would be damaging my HOME AMPLIFIER forcing it to run ohms its not designed to.
If im wrong, then let me know, otherwise help me out because ill be printing this for him to read.
Long story short: I bought a punch p3 for 130 dollars off of a friends friend, hooked it up to my house amp to see if it was blown, it was, hooked it up to my car amp, still blown, I know, dont flame me for it. You burn me once, shame on you, if you burn me twice, shame on me. My friend darren *who is the friend of the kid who sold me the speaker* says the kid is saying that the speaker wasnt blown when he sold it to me "obviously thats what he is going to say"
Im not too worried, 130 dollars isnt that much, plus I have a few things in mind anyways that im not going to mention on a freely readable forum.
Old Oct 26, 2006 | 05:43 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm no expert but in my experience of years of audio (guitar, PA, bass, car, home audio) the speakers are all universal as far as physically working. Sounding good is another issue.
Old Oct 26, 2006 | 08:26 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I once had a pair of MTX Blue Thunders (see who remembers those) hooked to my house stereo for about 2 yrs.
And I just recently removed a subwoofer I had in my Pontiac Vibe for a little more than 1 year that was from an old Bose Acoustimass 7 series.
The only way you'd blow one is (basically what you already said) if the impedence of the RF sub was too low for your home audio receiver to handle and the receiver started to clip.
Old Oct 26, 2006 | 10:12 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
That would be nice.
Power is what matters here. Just remember the 100W "home" amp is probably at 8 ohms. So the amp may try to dump 200W (in theory twice the current if output voltage stayed the same into 4 ohms in stead of 8 ohms, in reality at would be something less then double) into a "car" audio speaker. So as long as you didn't crank it, no, it would not damage the speaker. This IS bad for the amp tho.
Old Oct 27, 2006 | 04:15 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
The home amp didn't blow it. You would have to run massive distortion through it for a while to get it to spring a voice coil. If you hooked it directly up and it didn't make any sound, it was junk when you got it. Your "friends" are pulling a con job on you. As for 130 dollars not being much, isn't the principal of it worth much more than that? Go on any other audio forum on the internet and they'll tell you the same, a home stereo amplifier won't kill a car audio speaker unless driven ridiculously into distortion for a decent period of time. Tell your friends they suck.
Old Oct 27, 2006 | 11:16 AM
Polecat's Avatar
you can safely run any car audio speaker in any home setup, as long as the impedence is correct, I have been running our 12's in my home Pioneer setupo, for about 7-8 years.
Old Oct 27, 2006 | 11:29 AM
TA5point0's Avatar
Car: 89 trans am
Engine: 305 tpi
yea i had 2 12's hooked up to my home stereo for a few months with no problems at all.. i also have used my rockford 6x9s on my home stereo with no problems either.. the kid is bullshitting you, get ur money back from him
Old Oct 27, 2006 | 11:57 AM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
runnin a cheap set of wal-mart specials (road masters) in the shed on a boom box for a few yrs now sound rough but function..
Old Oct 27, 2006 | 01:32 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Yeah, he's going to get one heavy *** subwoofer thrown through his windshield late one night.
Old Oct 27, 2006 | 02:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
toss an old spark plug through his windshield, and or dump brake fluid on his hood. Those are my favorites.
But yea, I've also used a car audio sub in home theatre, worked fine.
Old Nov 1, 2006 | 01:37 PM
Joker1232's Avatar
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
if he wants to blow it just hook up some wires and put them into an electrical socket, that will fry it. I'm sure you would blow a channel on ur receiver if you hooked a decent car sub up to it.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
bbsr72
Apr 2, 2016 09:12 AM
92projectcamaro
Sep 29, 2015 07:07 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
