Looking for a car alarm
Old Jan 9, 2007 | 11:15 AM
Skull88's Avatar
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
What is the best and most inexpensive car alarm in the market today, can someone give me some brand names or links. Thanks
Old Jan 9, 2007 | 12:28 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I have an Autopage alarm in mine. I don't remember exactly how much it cost but somewhere in the $200-$250.00 range. It will page your remote if the car is disturbed.
I've had this alarm ever since my radio was stolen and the center console was destroyed in the process, about 6 months and I have no complaints so far.
Old Jan 11, 2007 | 04:29 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Try Code Alarm. You can also run the power windows from the alarm remote.
Old Jan 11, 2007 | 04:47 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
It all depends on what you want to get. You want JUST security? Want Keyless Entry? Remote Start?
Viper, for example, is going to be one of the top names out there. They back their products with a lifetime warranty. Zillions of brands make Keyless setups, but there are dozens of those brands that are pretty lame and will cause problems months after install.
Old Jan 13, 2007 | 08:24 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Sounds exactly like me, about the same time period and everything.. maybe a little less, although my auto page alarm was $483.51 professionally installed.
Mine is an Avital A4400, I love it. It tells me how they are getting in, through a door, the hatch, or if a shock sensor is going off, like a broken window or something. I recommend it.
Old Jan 14, 2007 | 10:03 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Any more details on the Viper? How much? Does it work with the VATS system well? How good is the keyless system?
Old Jan 16, 2007 | 09:13 AM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
Check out Viper.com
Old Jan 23, 2007 | 11:00 PM
89_KITT's Avatar
Car: 1989 Pontiac Firebird Mint. cond.
Engine: 2.8L V6
Transmission: factory
Axle/Gears: factory
i have a viper 5000 2-way LCD system and i got door actuators installed in both doors for $420 (with tax) and yes it works wit the VAT.i can open my car and lock my car and get a digital page showing whats wrong whether it be: 1. sensor 2. Door open 3. Glass shatter 4. tilt sensor(jacked up ) 5. MOtion sensor (T-Top models if ur parked and someone puts hand inside.
the tilt sensor, blass break sensor and glass shater sensor are extra but these alarms are sick u can also get a extra batt. and siren (if someone cuts ur alarm to bettery cable it will send a signal to a hidden alarm and it will go off again its a seperate unit for like 100 bucks more; good stuff
Old Jan 23, 2007 | 11:34 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Originally Posted by Mylilbowtie
Check out Viper.com
Viper is a brand name of DEI. Directed Electronics or something like that. I have had multiple VIPER alarms and they are excellent quality.
Old Feb 1, 2007 | 10:56 AM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
I have to look into that, I DON'T BUY prestige, that junk is affecting my headlamps everytime I turn alarm on or off! Andy
Old Feb 1, 2007 | 04:11 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
Not to still a thread, but I heard there is a system for T-tops as well. They say you can leave them off, when someone sticks there hand through the top, a sesor activates the alarms. I would like to have such a thing. Anyone know what I am talking about?
Old Feb 1, 2007 | 04:57 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
no but if you leave your t tops on and set your alarm (unless your not talking like 3 hours away from car like run into a store or something) then i could undertsnad that but to leave it off set the alarm and just leave the car there for more then 20 mins sounds like a dumb idea even tho they can be a pain in the *** to put on and take off
Old Feb 1, 2007 | 06:32 PM
If you're that worried about it, just put the tops on. It's not THAT much of a PITA.
Old Feb 2, 2007 | 07:11 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Another vote for Viper/DEI products. DEI makes a lot of different names. I have a Viper 300 (i think, dont remember), and it is loud as hell.
Old Feb 2, 2007 | 08:28 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
My Autopage alarm has keyless entry, shock sensor, ignition disable, and has infrared sensor for when I leave T-tops are off. Mine was also Professional installed, from a friend, so I probably got a deal.
Old Feb 2, 2007 | 09:13 PM
ajaciuk's Avatar
I have a viper in mine with the remote start. It has the spread spectrum technology and it also pages the remote if your in range if someone is tampering with your car. If I bought another one though I would get the Clifford alarm both alarms are made by DEI but with the Clifford you can adjust the shock sensor right from the remote.
Old Feb 3, 2007 | 07:40 AM
Car: 1991 Camaro RS
No, I'm not worried about it, I just think that was a good idea to whoever came up with it. I am just taying, you wanna run into a store real quick to get some milk and cereal, just set the alarm and run it.
Old Feb 3, 2007 | 10:23 AM
Dark Mavis's Avatar
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
Viper 791xv, alarm w/2 way pager - remote start. Can be had for about $150-175.00. I put it on my car, and it paid for itself in a few weeks after someone backed into my car while i was in a building. I ran out to find them starting to leave, but I caught them. Love the system.
Old Feb 3, 2007 | 11:14 AM
Car: 1991 Camaro RS
I have a quick question. Say I do want an alarm and I would like keyless entry and stuff. Does your car already have to be auto locks and windows and stuff. Mine is all manual. Am I limited to what I can get?
Old Feb 3, 2007 | 11:36 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
No, you can add aftermarket actuators that will work with the alarms remote and it's not that more expensive.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
