Dash speaker rattle
Old Feb 4, 2007 | 04:31 PM
83Chevy__Camaro's Avatar
Dash speaker rattle
Hi, i have the pioneer 4x6 speakers on the dash, because crutchfield said they would fit, but i cant put any power to them because they hit the dash or cause major rattle, im not 100 percent sure what it is, so i make the sound fade to the rear speakers to avoid rattle, any tips or suggestions to fix this problem
Old Feb 4, 2007 | 05:30 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
if ya got a sub and amp hooked up turn base off on the speakers and turn treb all the way , i got the same speakers you do it was what i did (well same type as you might not be exact same ones)
Old Feb 4, 2007 | 07:12 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
That's weird, I used to have them Pioneers in mine and had no problems. The 4X6 speakers I have now are actually bigger then those and I still have no problem. I did take the base out of them though like the guy before me said. I fronts are only highs, my back are mids and my subs are the low.
Old Feb 4, 2007 | 10:55 PM
i dont have sub or amp, just a pioneer cd player and it rattles so bad, like its hitting teh dash
Old Feb 4, 2007 | 10:59 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Well, if you don't want or need to use the outermost ac/heater vents (the large and small verticle ones) you can unbolt your dash and remove them and your speakers will drop right in. You can probably get some aftermarket ducting to run to them though if you don't want to ditch them. Just pay attention to the routing.
I have a 92 and I had to ditch them to make my Infinity Reference 4x6s fit. I didn't care about the fit when I bought them though. It was an after thought. I bought them for the sound. They are so deep though, I have to grind away some of the instrument pannel backing (not the actual panel, the concaved area in the actual dash) in order to get the driver's side to finish dropping in. I also need to grind away these odd raised ridges molded into the top of the dash. Why they made the changes they did I have no idea. My 88 was easier to do this crap on.
On a side not my 6x9 JL Audio speakers barely fit because of their depth. You can feel the magnet trying to pull itself to the sail panel.
Old Feb 7, 2007 | 05:44 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
can that be a good thing
and on a side note buy some front bass blockers from crutchfield
http://www.crutchfield.com/S-xW3fldq...p?i=127BB600A2
if you buy them and hook them up in the front , and if they still rattle its your speakers not the bass
Old Feb 8, 2007 | 12:07 AM
racer J's Avatar
Engine: 305 TBI
Depends I guess LOL. The metal in that area is fairly strong. I don't see anything bad happening as a result. It has a decent amount of clearance. It's just a big strong magnet.
Old Feb 10, 2007 | 10:04 AM
Thanks guys, maybe ill try those bass blockers.
jrdturbo
Mar 31, 2016 02:58 PM
86IROC112
Nov 7, 2015 06:50 AM
wanext
Oct 6, 2015 12:18 AM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
