Ebay F-body sub box??
Old Mar 13, 2007 | 10:42 AM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
Axle/Gears: 2 series 2.73 drum
I need a sub box for my 87 trans am. i've been searching all over and i keep comming up with the $50 ebay specials. I've found a few other boxes but frankly they all look the same but some sites want $200. I'm not new to the car audio world having done 3 complete systems and usually i know you get what you pay for. Anyone know if these ebay boxes are any good? the dimensions look right. i'd like to save some money here if i can. heres the link below not sure if it'll work
http://cgi.ebay.com/PONTIAC-FIREBIRD...QQcmdZViewItem
Old Mar 13, 2007 | 03:42 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
tbh best thing you can do is build one yourself... premade boxes arent that great.. unless your getting it from a small shop or from someone who really knows what there doing
Old Mar 13, 2007 | 03:52 PM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
good point but i've never built a sub box by myself and i really don't know what i'm doing i will say i did buy one prefab box for a car for low $ and was very impressed at how solid it was and comparable to the custom boxes of others. this is why i'm posting to see if anyone has first hand experience with these boxes from ebay or wherever. thanks for the help bandit
Old Mar 13, 2007 | 03:56 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
First...........welcome to the board.
Ask the seller how thick is the MDF. The specials might be only 3/8" thick. The $200 box might be 3/4".
I agree that the best bet is to have a shop custom make the box to fit your subs. A generic box will make some subs sound lousy. Get a box that is TUNED for the sub. NOT the other way around.
Good luck..............
Old Mar 13, 2007 | 04:39 PM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
true
all good advice bills. correct me if i'm wrong but the space for an f-body box is going to make most boxes around the same size right?? mabye i'm assuming too much but because of the strange trunk space to fill i feel like i kinda need to get a prefab then find a sub that will work with the box size. its a$$ backwards i know. don't you think 200 is a bit steep for a sub box? i'm actually picky about my car audio believe it or not but seems hight
Old Mar 13, 2007 | 07:43 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
hmm i see it said it is a sealed box... I wouldent get it, if you want good sound get a ported box plus Dual 12" subs in a small non-ported box you would want to hope there is a division in there or the subs will be fighting eatchother and it would sound c**p.
EDIT: just to add IF it has a divisoin in there it would half the air space inside the box for eatch sub.
Old Mar 13, 2007 | 08:23 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Well, having personally bought a box made just for our cars off of EBAY, I have to say that the one I bought was top notch quality.
The box itself was very, very sturdy to say the least, it IS a sealed box, the material on the box was quality stuff, the terminals in the back were done right, there is a division in the middle for each sub, and every seam/edge was glued tight with silicone.
This is a slightly old pic, my box is now covered with grey carpet to match the interior.
I bought my box for 25$, forget these custom places that charge 200$ a box, i'll take the EXACT same thing for a fraction of the price thank you.
And BTW, it sounds great too
Old Mar 13, 2007 | 09:57 PM
VenomX-87's Avatar
not saying it don't sound good now but if you ported that box say a 2" hole in eatch top corner you would get more BOOM with youre bass.
That dose look real good tho
Old Mar 13, 2007 | 11:09 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Hehe, the reason I wanted a sealed box was because Im going for sound quality, not flat out boom boom volume.
That tight punchy bass is what im all about
Old Mar 13, 2007 | 11:22 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Also, to do a ported box correctly, it requires MUCH more air space. I am doing away with (as in trying to sell - with speakers) a dual 10" (JL 10W6) enclosure, and having a new enclosure made for a single 12" which should outperform both of the 10's. Requires only 1.25 cf airspace sealed, but twice that if ported.
Old Mar 13, 2007 | 11:24 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Yeah, those alpines are 12's, and im extremely happy with them in a sealed box.
Old Mar 14, 2007 | 02:05 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
not to mention if you port it correctly you have to take into account the HZ you want the box to be tuned to. this decides the port length and size. Just drilling a 2 inch hole is NOT the answer to porting.
Old Mar 14, 2007 | 02:16 AM
VenomX-87's Avatar
i know that, my sub boz has a 3.5" hole and a tunel going from one side and almost to the other but that is with a Single 12" MTX RoadThunder 400W with the MTX Box made for my sub. it is killer but it is a big box for 1 sub.
Old Mar 14, 2007 | 08:45 AM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
thanks quisterio thats the info i wanted. i'll call them and make sure its sturdy contructin with a sub divider and then probly take the plunge. do you have a link for the one you bought off ebay? i think mine is the same "store" but can u check it out and tell me what u think? thanks
Old Mar 14, 2007 | 09:06 PM
TheBandit's Avatar
Engine: Poncho 350
i still wouldnt buy it no matter how sturdy it is.. like everyone said.. there not built to your subs specs.... plus if your paying $200 for that.. you might as well pay the 60 or 70 and go by the plans on this website.. my opinion though
Old Mar 15, 2007 | 12:06 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
I Dont Know Anything About My Subs' "Specs", Or "Required Airspace"....
All I Know Is This.....
In My Box.....They Sound Good.....VERY good..
Old Mar 15, 2007 | 02:02 PM
thirdgenSS's Avatar
my box was built for my subs...i dont like the slanted boxes so mine is built flush and i really like how it turned out it ran me about 190 to get it made.
heres the box out sitting on the rear deck while changing tail lights.
Old Mar 16, 2007 | 06:56 PM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
Here check out this thred.It has the dimensions for the sub enclosure in a pdf and a blueprint.It's basicaly same as above photos and like the 1 i build non-ported to handel my 12 inch infinity .Once ya have the box built just cut the lid ta fit yer sub and tune TO YOUR OWN TASTE.(IE.add insulation or ports or whatever ya like)But do it to suit YOUR ears not everyone elses.Mine at low volume sounds like thunder inside rollin down the interstate.At high volume the wife hears me comin inside the house when i'm about 5 doors down the road.(Aprox 1 city block.)When i have a bad night at work and blast my AC/DC for the hour ride home on the interstate my ears are lightly ringin for about an hr after i get home.
https://www.thirdgen.org/forums/car-...sub-box-2.html
Theres the thred.Enjoy.
Old Mar 19, 2007 | 05:40 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
i bought the same exact box as this guy here , i also have to say there extramly good
http://cgi.ebay.com/CUSTOM-12-SUBWOO...QQcmdZViewItem
one i bought
Old Mar 28, 2007 | 07:08 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
Re: Ebay F-body sub box??
Does the ebay box leave any space in between the very bottom of the well and the box to put my amp and what is the airspace volume of that box...I emailed the seller about 2 weeks ago...still no reply.
Old Mar 29, 2007 | 09:16 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
even if it does why would you mount an amp there? security I know but you will over heat the amp. it cools from airspace. if there is no air moving it overheats. unless you are talking about a completely different spot than I am thinking. just mount the amp with security torx screws.
Old Mar 31, 2007 | 08:33 AM
[R]ogue's Avatar
Car: 84 bird
my brother bought one of dem dere egay boxes for the firebird.... with 2 10" soundstreams @ 400watts he literally blew the box apart at the seams... you get what you pay for.
Old Mar 31, 2007 | 03:44 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
mines running to alpine type r's at 600 RMS... and it runs them at full blast none stop all day long...
but i am buying a ported box with the same exact designed going to be 2.3 cubed airspace tuned 32 hz , gonna blast =)
Old Mar 31, 2007 | 05:31 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
That is where I have my amp now and it doesn't overheat. I want it there to hide it, for a cleaner install because the amp I just purchased is 24 and a 1/4 inch long. I just want to see subs, but the box I have now, I can't run my JL subs or Type R's, not enough airspace in my tiny MTX sealed box.
Old Apr 16, 2007 | 11:25 PM
VenomX-87's Avatar
Just to show how criticle airflow is for an AMP.
I used a small temp probe with guage designed to fit in the radiator fins just to try this out i hooked it into the fins on the side of my AMP and ran it full blast for a 10 min in the open and in the bottom of the well with the sub over it, it was a 24'C hotter in the well and it was running at 28'C in the open (not moving but with back window up for airflow).
This reading was on a 22'C day so it was not very hot, if it was a 30'C+ day that reading would probly double.
this is a 1200W amp running 1x 250W RMS sub and 2x 100W RMS 6x9"s (roughly)
Old Apr 17, 2007 | 12:48 AM
jstoltz's Avatar
my point exactly I guess if you are running a 250-350 watt amp it isn't that big of a difference but if you are running two Alpine 1000 watt mono amps you have to have airflow. The reason behind most competition installs having an acrylic box around the amps alot of time is to mount high cfm fans to cool more efficiently and still have a visual impact. I have less to worry about than most on here though because I have a convertible (trunk instead of hatch) so it won't be seen most of the time but I have more to worry about cooling wise also.
Old Apr 17, 2007 | 01:31 AM
stagefright4's Avatar
Car: 1992 trans am tpi 350
Engine: tpi 350
how does that amp work with you p2's ive got a set of p2's but ive got the 800 watt fosgate amp to go with them.
Old Apr 18, 2007 | 10:10 AM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I just got my box built and it looks great and sounds great!!! I built it myself and it is getting covered with Medium Grey carpet tomorrow. No amp overheating yet, but before the summer I am putting a small 12 volt fan with a relay using the amp remote as a switch to supply a little air to the amp under the box. The amp isn't close to the box that much, but it is still getting no airflow because of the tight fit of the box. It is down firing with the amp and cap below the box so it is completely stealth. Here is a few pics with the camera phone...
Old Apr 18, 2007 | 10:15 AM
Hammertime540's Avatar
Car: 91 Camaro RS
Axle/Gears: 3.42's Locker
I orderd mine off ebay and I am happy with it. It fits good and pounds hard. I haven't tried anyother box so I could be missing out. But right now I need a new amp, cuz my hand me down amp is about 15 years old.
Old Apr 22, 2007 | 01:45 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I have the same box that everyone is calling the ebay box although I got it at my sound shop. I liked it. I was not concerned with ported sound. And there is enough room underneath to put your amp. My amp is there and I never had a problem with it. For $25-50 you can't go wrong. If you don't like it then sell it.
Old Apr 22, 2007 | 11:46 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
and FYI , it always sells if you put it in the paper or say cragslist heh , i sold 2 for 70 bucks each =) they were 12's with sony exploids i got for free but worked so i put them in the box and they sold
Old Apr 23, 2007 | 05:09 PM
hellsatan's Avatar
Car: 89 IROC
Any1 put two JL W6V2 in one of those ebay boxes?
I bought one and got JL w6v2 and the guy said it would work...
I hope so The box looks good tho nice carpet. I got it from same place as the rest of these ppl Hope it works
Old Apr 27, 2007 | 05:06 PM
houseparty4's Avatar
Car: Camaro z28
Engine: 350 TPI V8
Transmission: Automatic
I have one for my 2 12" Orion 1000 watt subs. The box is divided, carpet looks great, terminals are good but i dont use them, everything is sealed and its VERY sturdy... Fits great also. My subs hit very hard in them, my whole car shakes
Old May 2, 2007 | 05:23 PM
Horrible01's Avatar
Car: 91 camaro rs
Engine: 350 sbc
Transmission: b&m 350
Axle/Gears: borg warner 9 bolt
well not to be the forum negative nancy but.... did anyone notice that they used CAD drawings and CNC machines.... lol sounds sketchy to me man lol a cnc machines alone will run you about 50.000 for a bs one and cad software will also run you a couple thousand dollars..... The numbers don’t add up for me. I’m not saying the sub box won’t work but why all the hype??? If you really wanna impress me tell me it was made by ninjas with no thumbs
PurelyPMD
May 5, 2016 04:57 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
e3pres
Sep 9, 2015 01:51 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
